05-06-18, 03:22 PM | #1 |
Mini-splits - cheap vs not cheap
I am considering a 12K mini-split heat pump for the great room. They range from $479 to $1195 online, both with free shipping. Any suggestions or comments on getting what you pay for?
Even $479 is more than what I pay for three window shakers. These typically last about four years and seem to be impervious to lightning. I am mainly interested in getting the mini for its heat pump function as I am currently wasting a lot of money on resistance heat in the winter. I am not excited about punching holes and running wire and lines if I have to replace it in 2-3 years. |
05-07-18, 08:57 AM | #2 |
I have three Gree Terra series we use them every day and they have performed well. They are very quite and with AC use very little power.
Terra Series - Ductless Wall Mount Heating and Cooling | Gree Comfort If you are in GA I am in SC so we probably have a similar climate. Here is my install a few years ago. http://ecorenovator.org/forum/geothe...t-install.html
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 05-07-18 at 01:39 PM.. |
The Following 2 Users Say Thank You to pinballlooking For This Useful Post: | CrankyDoug (05-07-18), stevehull (05-07-18) |
05-07-18, 11:56 AM | #3 |
There is value in going with a recognized brand. The low price ebay units are completely different than those listed a year ago. My guess is that finding parts for them will be a problem next year when the listed brands change again.
05-09-18, 05:54 PM | #4 |
Steve Hull
Pinball - where did you but the Gree Terra from?
Great review that I was hoping to get a few weeks ago. Will get one - but from whom? Thanks!!
05-09-18, 06:12 PM | #5 |
Steve I thought you had already seen my review i also thought you were looking at larger systems.
I bought the first one’s from here. https://www.acwholesalers.com/ The second ones I bought from here they were cheaper. They had good deals where they combined line set and unit. https://www.comfortup.com/ If you want lower heating temps go with these units they heat down to -22 mine only heat down 5 degrees. Crown | Gree Comfort I really like mine but if I replaced them I would get the crown it has wifi remote control and heats much lower temp they are about the price I paid. I have never bought form these guys but they have good prices. http://www.energyconscious.com/hvac/...tml?brand=4575
Current project Aquaponics system , Passive Solar Greenhouse build To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by pinballlooking; 05-10-18 at 11:18 AM.. |
06-13-18, 08:05 AM | #6 |
From my research , one thing your money buys ( potentially ) on the more expensive units is a higher SEER rating . My advice is to buy the highest SEER rating you can afford .
We self installed 2 low cost units . Glad we did . I would not count on finding parts on any of them . We had the circuit board go out on a Fedrich unit during a brown out . They replaced it under warranty & I installed it myself . No problems with the circuit board since . Wyr God bless |
06-13-18, 08:27 AM | #7 | |
Where did you buy it and who took care of the warrenty?
08-07-18, 08:55 PM | #8 |
Small/medium sized mini-splits have higher SEER than larger ones. Single outlet/air handler units also tend to have higher SEER than one that can handle multiple air handlers.
06-13-18, 08:44 AM | #9 |
Bought it at Johnstone Supply . The company I work for has an account with them . So , I paid wholesale .
Went back to them to get the replacement board . I did the repair . I was expecting more than one circuit board , but everything was on the single board . I am running this ~ 12,000 BTU unit on 120 VAC . Apparently , the board converts the power to something similar to 3 phase . Wyr God bless |
06-13-18, 01:59 PM | #10 | |
Most of the mini splits step up the voltage to around 380V DC. Then they convert that to whatever the compressor uses. Most are three phase. Basically work like big commercial style power supplies. The big capacitors are what usually go bad as with all electronics everyone uses cheap caps. So be careful when messing with those boards as the caps can bite you if you forget to discharge them. I keep thinking about a minisplit in the kitchen. In the summer you really don't want to do much cooking because its already 100*+ and the AC is already running non stop... A nice small minisplit would make the kitchen much more usable in the summer. I'm thinking ceiling mount but they are pricey still. Though I do have a spot for a wall mount and the smallest unit would do what I need. |
