Old 02-18-16, 07:47 AM   #1
pinballlooking
pinballlooking's Avatar
Default What is your biggest power usage day?
Some it could be in the summer others it will be in the winter.
What is your largest power usage day? Maybe the day you did laundry and it was cold out or hot outside.
I will start it off we hit a 100 kwh this winter. We charged the car 3 + times. Each complete charge is about 12 kwh car charging was about 40 kwh. a normal day it is 24 – 30 kwh in the winter.
Our dryer has two heating elements and use 6.6kwh when both are on. It was a very cold day….
I should add that day was sunny and we made 70 kwh with solar power.
I know we don’t talk much about max usage but the talk about going off grid had me thinking about it. You have to plan for the worst days not the best days.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Old 02-18-16, 08:05 PM   #2
where2
DIY Geek
I think my worst day in my power tracking history was 56kWh. When my electric heat strips kick on, they're 10kW of glowing resistance heat. I've been lucky this winter, a majority of the winter I've been able to heat with a dehumidifier. Looking at my thermostat, I've only had the heat running for 3.75 hours in the past 10 days.
I've got a friend who lives near Roanoke, VA. He sends me photos of his TED 1001 reading over 100kWh per day several times each winter. He sent me a message yesterday and said his power bill was 3337kWh last month!! He's got a 90+ year old house that desperately needs a Thermal Imaging camera and air sealing help.
Old 02-19-16, 10:09 AM   #3
celblazer
53.3Kwh It was 0 here and barely above for a couple days. I have an outdoor Hot Tub and that just sucked down the energy. My winter average is usually 35-40Kwh when it's cold.
celblazer is offline   Reply With Quote
Old 09-01-17, 02:13 AM   #4
Kanka
Ikr, these hot tubs use so much energy.
Kanka is offline   Reply With Quote
Old 02-21-16, 11:29 AM   #5
oil pan 4
Land owner
You can reduce peak power draw of an electric dryer like I did here:
http://ecorenovator.org/forum/applia...-selector.html
It works real good in hot dry climate like I have.
If you are starting with 100% humidity air like you get on the east coast, might not work as well.
Old 03-01-16, 02:41 PM   #6
Piwoslaw
Piwoslaw's Avatar
Our house has the highest electricity use on Christmas Eve - lots of cooking, baking, cleaning, plus the christmas lights are already on. This is usually the only day in the year when we use more than 10kWh (typically 12-13kWh).
As far a total power usage (including gas for heating) then that would be the coldest day of winter. Our condensing boiler can use as much as 15-20m3 in a day, which is about 175-225kWh.
Old 03-01-16, 06:19 PM   #7
mejunkhound
Do laundry only once a week, Saturday.
2 large dryers, typical is 70 kWhrs.
Largest on our record is 170 kW-hr, one fall day last year when dryer was used and I spent 5 or 6 hours welding out at the barn, 230A dc welder, and house needed some heat.
5 T GSHP and 3T air-air HP, neither run at same time though. Electric WH (hybrid).
DW may have used the 10 HP pressure washer a couple hours that day also.
Old 04-16-16, 08:04 AM   #8
Servicetech
Servicetech's Avatar
50KWH during the heat of the summer. 100+ degree days will do that !!!
Old 06-24-16, 09:47 AM   #9
nupur
Mine was during summer when the mercury was soaring high. the air conditioning was on all day, must've used up atleast 50 kwhrs.
nupur is offline   Reply With Quote
Old 11-27-16, 11:01 PM   #10
wilsonsmith
Banned
During summer the usage of power is much higher than the normal seasons. Due to high temperature of 100 degree or more, we should keep ac on for the whole day. Regular electronic appliances cost more power usage during summer. Our largest power usage is 100 kwh per hour.
wilsonsmith is offline   Reply With Quote
