Old 03-23-15, 10:58 AM   #41
Default Solar PV & Heat
Here's a clever approach, where the heat that you are trying to get rid of, has been ingeniously utilized...
ROSE_HOUSE-1
ROSE_HOUSE-2
ROSE_HOUSE-3
Old 03-23-15, 01:22 PM   #42
Pinball, would you mind sending me specifics about those $0.74/watt panels? Secondly, is the space above the panels or between them. The spacing for the Enphase wire connecting panels is at a fixed distance so I can't put too much room between them on sides or the connect spot would not be below panel.
What would you recommend for spacing? I have lots of room on the big shop roof.
Thanks - and it is good to be back on reading and such.
Old 03-23-15, 01:30 PM   #43
You can see it in this picture.
They are 4-5” up off the roof and you can walk between them to change out a microinverter.
I had to mount them that way so I could bolt the racks into the rafters.
I still used the portrait cable it just runs from the bottom to the top.
The landscape cable is more money and adds to much voltage drop.
I sent you a message on the panel prices let me know if you don't get it.
shop building, sips
