Old 03-12-15, 08:25 AM   #11
gtojohn
gtojohn's Avatar
Thanks for the research and responses. The tote location will be underneath a pier and beam crawlspace, back edge of structure sloping down hill, so no immediate threat. My biggest loss would be the that much rain water. 140f X 330 Gallons should be plenty for dhw. I'm toying with low temp hydronics during our winter, not too cold here, and I do have a back up heater. If I can produce 140-150f x 330 gallons during the winter I'll be ecstatic, and if I can do more I'll expand my storage.
Like so many things on this board it looks like someone has to try it and see if it works!
Old 04-07-15, 10:09 AM   #12
ideamaster
sort of off topic. Have you thought about just making a potable water cistern? Check the specs for QUIKWALLa Surface Bonding Cement #1220 - #1231 (sorry I can't do URLs yet).
It could be coated with something like americoat 240 to give it a black color to pick up heat.
ideamaster is offline   Reply With Quote
Old 04-08-15, 03:50 AM   #13
ferox
My plastic tank have 1000L, was tested in the first start to 85C.
All 4 beer keg with 9 bar.
All works good, from 2013.
Pictures here
http://ecorenovator.org/forum/geothe...mp-backup.html
Now I work with 55C on tanktop and 50C on tankbottom, the Arduino controller start the heat pump just onece a day at 3PM when the outside temperature is maximal.
I instaled an external 24k AC unit with a 10mm copper coil 40m (I'm sure 30 is enough)
You can see some data here
https://personal.xively.com/feeds/899471984
ferox is offline   Reply With Quote
The Following 2 Users Say Thank You to ferox For This Useful Post:
gtojohn (04-10-15), Mobile Master Tech (03-05-16)
Old 04-10-15, 02:39 AM   #14
gtojohn
gtojohn's Avatar
Thanks Ferox! 85c=185f and 55c is 131f. I can work within those parameters. I haven't bought the tote yet, I'm still framing. 2nd floor is decked and roof framing is next. Its been hot enough here hot water won't be a concern for another 6 months.
