Old 06-01-11, 08:55 PM   #41
mejunkhound
" any propane tank works"?
Yep, my acetylene regulator screws right onto a BBQ tank, no separate costly tank needed. Same LH threads on both type tanks.
Have used propane for the cutting torch exclusively for about 20 years. Only time I use acetylene anymore is the rare torch welding of steel, such as for lift rings.
Old 06-06-11, 11:49 AM   #42
cmroseberry
I have done plenty of brazing and silver soldering with just a propane-air torch ($30). The best information I have gotten on technique is from "Soldering and Brazing by Tubal Cain, Workshop Practice Series #9" from Nexus Special Interests.
cmroseberry is offline   Reply With Quote
Old 06-06-11, 01:08 PM   #43
A few years back, we got a new BBQ and it had a new type of connector..
Will a standard acetylene regulator screw into the old style or the new?
Old 06-06-11, 01:19 PM   #44
I'll look it up and check it out.. I've done a lot of plumbing with copper,
so I've got a starting point anyways..
Old 06-12-11, 11:20 AM   #45
Have you run out of gumption on this project?
Want to sell your unit?
Old 06-12-11, 11:52 AM   #46
I'm a bit distracted by other stuff now. My Solar back-up system, solar screens etc.
I'll get back on the repair, sooner or later.. Even if I can't do the repair, all the spare
parts on this leaker might be very useful someday.
