Old 03-05-14, 07:56 AM   #11
iamgeo
Funny you should ask.
Monday morning I awake to frozen pipes. As the day progressed, the pipes started to thaw. As you can see here the 3/4 inch PEX and CPVC was pushed right out of the connectors. Damaged them on the inside. No busted pipes or tubing though.
The Following User Says Thank You to iamgeo For This Useful Post:
buffalobillpatrick (09-10-14)
Old 03-05-14, 08:49 AM   #12
MN Renevator,
Yes, PEX expands if ice forms and then goes back to former state when thawed with no ice or future problems.
Old 03-05-14, 07:05 PM   #13
That's the thing about the push-lock or shark bite fittings. They go together a little easier with less tools, but when the ice hits the fan, the ice wins. With the crimp or compression fittings, they are strong enough that the pipe will stretch.
The theory behind it is this: In a run exposed equally to sub-freezing temps, the metal fitting will freeze first, due to its higher thermal conductivity. The expanding ice water will grow into the pex pipe. The pipe stretches and the fitting survives. If the run is not equally exposed to cold and the pipe freezes first, the metal fitting may not survive. Same thing during thaw.
Old 03-20-14, 08:40 PM   #14
Wow, for the number of sharkbite fittings I see in your pics, you could have afforded the PEX crimp tool.
Old 03-22-14, 10:36 AM   #15
iamgeo
There are quite a few. I like the idea of being able to remove the fittings at will. That's why I went with those type fittings.
