Old 12-06-17, 01:12 AM   #1
gtojohn
gtojohn's Avatar
Default Solar powered UV light purifier
I had a thought while in an attic the other day. Why not use a solar tube light to sanitize my attic mounted a/c plenum? No power consumption, no bulbs to replace. Considerably more output than 14 watt fluorescent. Material cost is about the same for basic germicidal UV-c.
1.47 kw solar, R-40+ attic insulation, 4 layers radiant barrier, solar attic fan, solar mini pool pump
Old 12-06-17, 02:51 PM   #2
oil pan 4
Land owner
If there is any plastic in between the light and water it will block around 99% of the UV.
Then sun light allows other stuff to grow.
