Old 04-26-16, 09:36 AM   #1
Default Adding a spool gun to a Hobart 140/135
The Hobart 140/135 did not come with spool gun ready. That is the one thing I wish it did.
Will here is a video on how to convert it to handle a spool gun.
I know a couple of you have a 120V Hobart welder this might be interesting to you.
I might build a Big Green Egg table aluminum is probably the best material for this stand.
Daox (06-02-16)
Old 04-26-16, 05:10 PM   #2
Idunno, man. Anything under 200-250 amps I have welded aluminum with, I have burnt up. I even torched one of the new pulse Millermatics last year, not even using pulse. Push pull gun with a whip. On smaller/pretty jobs, I would much rather TIG weld aluminum, given a choice.
Old 04-26-16, 05:14 PM   #3
When you say burned up. Are you talking about what you are welding or the welder?
Old 04-26-16, 08:50 PM   #4
The welder. That millermatic just rolled out the magic smoke one day. I think it was a 350P. The dealer just swapped it out for another for who knows how much.
Looked like that.
