Old 08-16-15, 01:19 AM   #21
You can emulate the center channel by sending the signal to both speakers. Very easy to do in the analog domain (can be done with as little as 4 resistors) but not so easy in the digital domain (FPGA would be the easiest, which is not at all beginner friendly).
Old 08-19-15, 05:41 AM   #22
OffGridKindaGuy
Hi-Tech Hillbilly
OffGridKindaGuy's Avatar
I build 5 volt amps with Bluetooth. (3 watts/channel) Will run all day on a 5 volt bank battery. (5600 maH.) Impressive on some sensitive speakers..
The Following User Says Thank You to OffGridKindaGuy For This Useful Post:
jeff5may (08-19-15)
Old 08-19-15, 07:45 AM   #23
OffGridKindaGuy
Hi-Tech Hillbilly
I also build my own Boom Boxes with these combos. Anyone wanna see some pics?
Old 08-19-15, 07:55 AM   #24
Put em in the thread where I won the badger solar panel.
Old 08-19-15, 08:00 AM   #25
OffGridKindaGuy
Hi-Tech Hillbilly
OK.. Will do tonight..
Perfect match for that systerm..
*They's over there..
