Old 12-23-11, 08:46 AM   #11
pinhead
So then I got the electric kettle out.
1.416kwh so measure for 3:56
1 liter
17.2°C
t=1 - 39°
t=2 - 55°
t=3 - 82° - eff from here
t=3:56 - 89°
Rise = 64.8°, 4.175 x 64.8 x 1000 = 270734j
5097600j/h -> 254880j
And I did it all because I intended to argue that electric heat, being the inverse of efficiency, could not achieve 100%.
pinhead is offline   Reply With Quote
Old 12-23-11, 09:55 AM   #12
It looks like you proved that when you used it, electricity was 5% efficient.
You may have achieved a new low in energy efficiency!
So what will your next experiment be?
Old 12-23-11, 11:07 AM   #13
pinhead
Even worse than the electic use being 5% efficient, it showed that the water absorbed more heat than I put in. Sense I did not test it in my neighbours hot tub I assume that I just didn't mix the water thoroughly when taking the temp readings.
I think my next experiment will be on something even more generally accepted, like the shape of the earth...
Last edited by pinhead; 12-23-11 at 11:09 AM.. Reason: wrote it in some awesome language that was not english.
Old 12-23-11, 12:21 PM   #14
Hehehe.. There are no Free Lunches.. However, inverter heat pumps are semi-free..
Old 12-23-11, 04:53 PM   #15
...it showed that the water absorbed more heat than I put in...
In that case, I think you have invented a hyper-efficient heat sink.
Wow! A black hole right there in your own home!
