Old 05-22-14, 11:42 AM   #1
Nonhog
Knows enough to be danger
Nonhog's Avatar
Default Add insulation?
My rear facing wall of my atrium had some rot issues due to poorly installed vinyl siding. So I can do it simple and just replace the rotted siding and leave well enough alone or.......
I can add insulation to the small voids where it never had insualtion.
Understand this is an unconditioned room in the middle of our house.
Use to have a hot tub.
The inside walls were sheeted then covered with cedar T&G.
I'm concerned about trapping moisture. The voids are less than 24" square.
With a glass roof will it even matter?
Thoughts?
Name:	atrium wall 003.jpg
ID:	4388   Click image for larger version
Name:	atrium wall 004.jpg
ID:	4389   Click image for larger version
Name:	atrium wall 005.jpg
ID:	4390   Click image for larger version
Name:	atrium wall 006.jpg
ID:	4391   Click image for larger version
Nonhog is offline   Reply With Quote
Old 05-22-14, 11:45 AM   #2
Nonhog
Nonhog's Avatar
To clarify the voids are on either side of the windows not above them.
Old 05-23-14, 01:51 AM   #3
If you just use fiberglass insulation you will not air seal it , it will still breath.
Insulate with fiberglass then put up Chip board then tyvek then the siding would be my approach.
The Following 2 Users Say Thank You to ecomodded For This Useful Post:
Nonhog (07-03-14), stevehull (05-23-14)
