12-13-10, 10:40 AM | #1 |
Make your own remote power switch
This is a good idea. Its perfect for an entertainment center or computer. I've been thinking of doing something very similar but with an extension cord and actual light switch. I'd just mount the light switch to the desk somewhere to turn the power on to all the computer stuff. My computer uses 9W when off, having a switch like this would save me ~6 kWh a month.
Make your own remote power switches
12-13-10, 12:06 PM | #2 |
I've been turning off my PC room loads, when I'm not using it.. It's a messy setup, but it works.
After installing some X-10 stuff at my daughter's house (controlled by alarm system), I had two left-over X-10 appliance modules (suitable for CFLs). I decided to use them to control two out-of-the-way Nite-Vamp power sucker outlets. Back of the Plasma TV and entertainment gear. In the living room, beside the a small TV in a room divider. Had to buy a little control box. It sits on top of the microwave. I was pretty impressed by the small amount of power used by these devices. Especially when compared to leaving the equipment parasiting, while not being used. |
12-13-10, 01:12 PM | #3 |
Interesting but I'm not too sure where I have left to install one. My main phantom load center is the PC area and I run two power bars for it, one below the desk stays on since the PC stays on 24/7 the other one above the desk stays off unless I need the scanner/ham radio/speakers/external HD... I should add the monitor to it as well I suppose.
02-11-14, 12:45 PM | #4 |
I love looking through old forum posts. So much good stuff! I'm bumping this one because I think its cool.
02-11-14, 03:24 PM | #5 |
I just got one of these for the bedroom entertainment equipment.
Belkin International, Inc F7C01008 - Best Buy I got it for $25.99 shipped from newegg. six outlets are controlled by the remote. Last edited by Daox; 02-11-14 at 03:40 PM.. |
02-11-14, 03:42 PM | #6 |
Cool. What kind of batteries does the switch use? When you get it, could you write up a review for the new review's forum?
02-11-14, 03:50 PM | #7 |
23A 12v small battery just like my other remote control power strip. I have been happy with my other smaller power strip. I have a quest to get my vampire loads under control and these should help.
I would be happy to review it after I use it for a little while. I did read a few reviews on it and people really seemed to like it. I hope I have the same results. It is set up pretty good for wall warts Last edited by pinballlooking; 02-11-14 at 03:52 PM.. |
The Following User Says Thank You to pinballlooking For This Useful Post: | Daox (02-11-14) |
02-11-14, 05:11 PM | #8 |
I'm still loving my Ecorenovator Smart Strip.. When the PC takes a nap, the Smart Strip
shuts down all the other loads, until I come back in and move the mouse..
02-12-14, 02:25 PM | #9 |
I use something similar for my home theater. The only device that receives power is the receiver, and when that is turned on, the power for the Roku/Blu Ray player/switch/Wii and the amplifiers for the front channels come on. I'm not sure how much power it really saves, but it must be a couple watts worth of LEDs alone.
