Old 07-08-19, 10:51 AM   #1
pinballlooking
pinballlooking's Avatar
Default I ordered a 4x4 CNC plasma table
I did a fair amount of research looking at build /buy a CNC table. I was close to making one but in the end buying just made more since.
I would have had more money in building one.
I have a lot to learn just in software to use it. It will be about 8 weeks before I get it. They build to order and they just had a sale.
I am getting a water table to keep smoke down and warping to a Min. It has torch height control.
I will be using my new plasma cutter on it. I will have to buy a CNC port board and a machine torch.
Delusional Designs
https://www.delusionaldesignscnc.com...ter_Table.html
I am not sure where our focus will be yet. I will be selling some stuff I cut but I would like to keep the finish and painting part to not much as this is a side business.
I am probably limited to ½” and under cuts. I will add an extension to the table to all put a 4’x8’ sheet on the table. If we like doing this we will buy a table extension to expand this table to 4’x8’ table.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Fordguy64 (07-09-19)
Old 08-07-19, 09:23 AM   #2
Have you used it yet?
Old 08-07-19, 04:02 PM   #3
pinballlooking
I actually canceled this one and I am going to order the next model up from this one that uses linear rails better software. It will let you continue from the spot you had a issue. I am going to get the 4 x 8 table as this one is harder to upgrade later. I was able to get a machine torch off Ebay that had been only used once for a killer price. That will help with some costs. But I have to buy a bigger ticket compressor.
EV Chevy Volt -
Old 08-07-19, 04:35 PM   #4
Sounds fun. Do you have lifting equipment? A 4x8 sheet of metal can weigh a lot.
Old 08-07-19, 04:46 PM   #5
dremd
Need More Eco
dremd's Avatar
Send a message via AIM to dremd
Sweet dude!
I have a 4x14 plasma cam setup with a Hypertherm Powermax 45 on it.
What cutter are you planning on running?
If there’s anything you think I might know feel free to hit me up, but as I’m sure you already know Jim Colt is THE authority on small CBC plasma setups.
dremd is offline   Reply With Quote
The Following User Says Thank You to dremd For This Useful Post:
Daox (08-07-19)
Old 08-07-19, 04:49 PM   #6
dremd
Need More Eco
dremd's Avatar
I see you are interested in a water table, unless where you are venting to is smoke critical I wouldn’t. I had a water tank in mine and ended up pulling it out because it was a pain to clean and only helped so much.
Old 08-07-19, 05:15 PM   #7
pinballlooking
My subcompact tractor has quick attach pallet forks. It can lift the steel. I also have a hydraulic lift table that I move pinball machines around with that can lift 1,000 pounds.
EV Chevy Volt -
Daox (08-07-19)
Old 08-07-19, 05:17 PM   #8
pinballlooking
Yes I getting a water table. The new one I am ordering will come fully assembled. I have a thermodynamics 60i I just bought a 50' machine torch for it.
EV Chevy Volt -
Old 08-07-19, 05:19 PM   #9
pinballlooking
Originally Posted by dremd View Post
Sweet dude!
What do you mostly cut with yours?
EV Chevy Volt -
Old 08-07-19, 05:30 PM   #10
dremd
Need More Eco
dremd's Avatar
Originally I cut 20, 16, and 12 ga steel.
Now it spends its days cutting.040 ,080, .125 aluminum mainly in 5052
Typically daily cut time is only around 2 hours with run time closer to 2.5 hours. Typically 5 days a week, but that varies by season.
