Old 10-05-15, 06:39 PM   #31
MEMPHIS91
MEMPHIS91's Avatar
Jeff, THAT MAKES SENSE! I guess I thought it was the violent action of the brazing that forced the black stuff into the pipe, I was assuming any gas flowing out would stop this from happening, but since your wisdom has once again kept me from doing stupid things, I TOTALLY understand now. THANK YOU. I got some old paintball co2 tanks laying around. Could helium tanks (the pink ones) be a good option? I'm not sure how expensive they are.
pinballlooking, I will try to get some pictures of my setup posted soon. The basic idea is the condenser is 20 feet of 316 stainless steal coil in the bottom of the fish tank. Stainless has no effect of the fish. I should have that part finished by the end of the week.
I got some more done today. I went with 1/8" for the oil return line.
pinballlooking (10-05-15)
Old 10-06-15, 06:29 PM   #32
MEMPHIS91
MEMPHIS91's Avatar
Well I didn't get to far today, I did get the reversing valve hacked. I clamped the suction side closed and extend the tube from the solenoid valve to the suction side of the compressor.
Here are the pictures of my AP setup. Got 8 barrel halves and 4 grow towers with a IBC tote and 35-40 brim. Been going for over a year now. This is only phase one, phase two will be 14 more barrel halves.
Water and air pump are both solar powered.
And the view at night when the LED lights come on.
ID:	6015   Click image for larger version
ID:	6016   Click image for larger version
ID:	6017   Click image for larger version
ID:	6018   Click image for larger version
Old 10-06-15, 08:53 PM   #33
Thanks for posting pictures of your system. Do you get good growth over the winter? What temp does your water stay at?
Old 10-07-15, 05:28 PM   #34
MEMPHIS91
MEMPHIS91's Avatar
I didn't get much done today I had a regulator on my oxygen bottles mess up.
pinballlooking, The system did ok last winter, but I was unable to keep my water warm. I will have the temp set to 65-70F this winter.
Old 10-07-15, 09:40 PM   #35
Pardon me for asking, but why did you close off the suction line of your reversing valve?
Old 10-07-15, 09:58 PM   #36
MEMPHIS91
MEMPHIS91's Avatar
Because I am not switching the direction of flow. It will only heat, I just need it to switch from sending heat to the air condenser to the water condenser. But I still needed the suction to operate the valve.
Old 10-09-15, 07:02 AM   #37
Aha, that's what you're doing! Solenoid actuated switching of heat between your aquaponic fish tank and greenhouse airspace is brilliant. I assume your fish tank will have another dx coil in it, not a forced flow hx. When this dx coil is disconnected from the compressor discharge, its outlet will have discharge pressure present, which will tend to fill the coil with liquid backwards. In essence, the dx coil will act as a subcooling liquid receiver. This will affect your system charge and hold some oil as well. Considering your dx ground loop size, a suction line accumulator near the compressor would be a prudent addition.
MEMPHIS91 (10-09-15)
Old 10-09-15, 07:16 AM   #38
MEMPHIS91
MEMPHIS91's Avatar
Yes I though about the different size/pressure/temps on the air source/fish tank condensers. And yes it will be DX, 20 feet of 1/4" 316 stainless steel. The compressor has a small accumulator on it already and I'm going to add 2 loops into the 3/8 copper coming into the suction side. Do you think adding a full size larger accumulator would be needed?
I had a set back yesterday, but I got it fixed last night, and will post more pictures and a update tonight. (More tools had to be bought. )
Also I am cutting the dual cap tubes in half, therefore making 4 cap tubes. The idea behind this is I KNOW they will need to be shorter like with the HP Water Heater. This will allow me to crimp one shut without having to open the system again and again, then once I know the needed length, I'll make the prefect size new one and fine tune everything.
Old 10-09-15, 05:39 PM   #39
MEMPHIS91
MEMPHIS91's Avatar
So today went MUCH better. The problem I ran into was that I cooked my reversing valve. I had been very careful but using map gas, but it just has WAY to wide a flame, and it takes much longer to heat up therefore heating the entire valve enough to cook the nylon o rings on the piston shuttle.
So I found the cheapest reversing valve I could find in town and picked up a nice torch set.
I got everything brazed back up!
And I started on the electric side of things.
From left to right. On/Off, High side and low side temps, and INK BIRD controllers that will be displaying air temp and fish tank water temp.
More to come soon.
Shalom
ID:	6036   Click image for larger version
ID:	6037   Click image for larger version
Old 10-12-15, 08:00 PM   #40
MEMPHIS91
MEMPHIS91's Avatar
Got all the electric done, fan guard built (there will be a grate over the blades when I'm done), and the Discharge/suction gauges installed.
ID:	6056   Click image for larger version
ID:	6057   Click image for larger version
