Old 06-15-13, 06:27 AM   #11
One more pic of the first layer mostly done. I didn't want to sandwich the outer layer because the screws that go through may not have enough strength to hold all the siding on without sagging and possible shearing off over time.
Old 06-17-13, 08:20 AM   #12
Looking good. Are you using anything to air seal the foam boards?
Old 06-17-13, 08:41 PM   #13
here is a few more pics. I will seal the foam around the window and door and anywhere that there is any holes. Then the Tyvek will go over it, hopefully before the weekend.
ID:	3230   Click image for larger version
ID:	3231   Click image for larger version
Old 06-30-13, 06:34 AM   #14
A couple more pics. The tyvek is going on and the 5/8" strapping with ridge vent mesh is going at the bottom and the top of the rain screen to kepp the bugs out.
ID:	3251   Click image for larger version
Old 07-15-13, 11:40 AM   #15
Pierre
I'm impressed. Well done.
Pierre is offline   Reply With Quote
Old 07-16-13, 05:40 AM   #16
One more pic of the progress:
Old 08-19-13, 02:15 PM   #17
Its looking great. Are you finished up yet? Can you tell any differences yet?
Old 08-20-13, 06:12 PM   #18
NeilBlanchard
NeilBlanchard's Avatar
This is a great way to go. The challenge will be to waterproof the extensions of the fenestration. Are you going to use brake metal flashing?
Old 08-21-13, 07:24 PM   #19
Interesting, we put the windows and doors in 5 years ago with an eye to doing the insulation after, but you know how time goes. As you can see, the windows and doors stick out a good 5" from the brick and there was 1.5" of SM put on the "box" before it was flashed with aluminum. I butted the siding right up to the aluminum and will just calk it in place. Not ideal but not too bad either.
Old 08-21-13, 11:06 PM   #20
Interesting, we put the windows and doors in 5 years ago with an eye to doing the insulation after...
Wow, your project should make a tremendous difference, not only with the added insulation, but also with tons of bricks as a thermal buffering mass that will now be inside your thermal envelope.
Keep us posted... you haven't by any chance been datalogging your indoor temperatures by any chance have you? Nice to be able to see the data of a before and after.
