Old 05-19-13, 08:08 PM   #1
greif
a van down by the river
Default thermal controller
Anyone know of a low cost thermal controller, in the summer I run my panels through a heat exchanger and into the pool, just looking for a low cost or if any one has a used controller. I want to turn pool pump on with it so would like a 20 amp if possible, pump motor is only 15amp but would like a little heavier.
Thanks
Gary
Gary R
Old 05-20-13, 09:44 AM   #2
If you wanted to boost the wattage of a standard controller, you could do it easily with a 25A SSR.
Just plug in a wall-wart to the controller's 120vac output and use the DC to switch on the 25A SSR.
Which will control the 20A ac line into your motor..
25A SSRs are only a few bucks on Ebay..
http://i46.photobucket.com/albums/f1...r/P1000835.jpg
My old controller only ran 10A max..
http://i46.photobucket.com/albums/f1...r/NCL/F015.jpg
http://i46.photobucket.com/albums/f1...r/NCL/F017.jpg
But it would be cheap and easy to boost it's power capabilities.
Be aware, that 20A x 125vac is about 2.5kw and most household sockets won't handle that kind of power. (15A breakers or fuses).
