Go Back   EcoRenovator > Introductions
Old 11-13-11, 08:47 PM   #1
rhizomatic
Default New to the forum
Hello. At last I start using this account.
My gas heating furnace is toast (the service board has shorted and the igniter is burnt). I live in Southern California and am in the midst of a long-term, slow-as-the-money appears, renovation. We will go without the heat this winter (we have the fireplace). No problem. But if you were renovating a house on a raised foundation, crawl space underneath, and no attic, what might you do for a more ecological sound heating system? I was wondering about electric, powered by solar. Geothermal seems very expensive to do right.
james (California98Civic on ecomodder.com)
rhizomatic is offline   Reply With Quote
Old 11-14-11, 12:52 AM   #2
strider3700
electric powered by solar is probably the most expensive method of heating you can do short of burning cash instead of wood in the fireplace.
Depending on your solar exposure why not insulate the crawlspace and add radiant heat under the floor. Add solar hot water heating and then pump that water through the tubing.
I'd love to do this - A Simple DIY Solar Space and Water Heating System
Old 11-14-11, 08:47 AM   #3
Piwoslaw
Piwoslaw's Avatar
Welcome to ER
Strider is right about solar->electric->heating being the most expensive (and least efficient) option. Iirc SoCal is known for its sunny weather and mild winters, so you could probably seal and insulate enough to not really need a furnace. The saved money could go into solar hot water and/or and air source heat pump.
Old 11-14-11, 08:47 AM   #4
Ryland
I see no reason that an air source heat pump would not work perfectly for you, what's the coldest that you see there?
Old 11-14-11, 08:57 AM   #5
I've been to Socal and IMHO, it's idea for an ASHP..
Average Weather for Riverside, CA - Temperature and Precipitation
Especially during the summer..
Old 11-14-11, 09:02 PM   #6
rhizomatic
[Average Weather for Riverside, CA - Temperature and Precipitation]
Thanks for these replies. Does it make any difference for ASHP that my coastal micro-climate is much cooler and wetter than Riverside? (Think Bogart and misty trench-coat scenes from "The Big Sleep".)
Old 11-14-11, 09:41 PM   #7
My Sanyo units are doing pretty well with high humidity.
Check my humidity chart.. http://pauland.net/monthly.php
Since your lows aren't really all that low, you shouldn't have many defrost cycles (if any).
I'm not sure, but it might be easier (less watts) for an ASHP to suck the heat out of moist air,
verses very dry air. Hehe, if it works anything like a GSHP..
This past summer, when we had mild, but very humid days,
our main Sanyo worked great as a whole-house Dehumidifier.
But sometimes made it a little too cold for me..
The cooling is fantastic.. Plus, these things make very little noise..
Old 11-14-11, 08:46 AM   #8
Unless gas is dirt cheap, electric heat can work, since you might be in a prime location
for using an ASHP (Mini-split inverter heat/cool system).
Check out the Geothermal - EcoRenovator area for ASHP & Mini-split installs.
In my case, using a Mini-split is saving us a lot of money on heating (and cooling).
Since we can't get gas, and fuel oil is priced like gasoline.
The idea of adding on solar PV to power the AC is a good one, but even without it,
my investment in ASHP hardware is netting us excellent savings, even at 21.6 cents/kWh.
Bottom line, running an Inverter mini-split is so cheap when you have reasonable
electric rates, the break-even point for a PV investment could be a loooong ways out..
Old 11-15-11, 12:19 PM   #9
Welcome to the site James.
It definitely sounds like an ASHP would fit your bill quite well with the mild climate. Of course, sealing and insulating are always easier and cheaper to do first.
Old 11-15-11, 12:59 PM   #10
That may not necessarily be the case for homes built in a very mild climate zone.
Especially, if the renovations were going to cost big bucks.
Average High/Low Temperatures for KNKX : Weather Underground
If the the outside temperature is pretty mild most of the time,
(like in SoCal where it hits the 80s during Jan & Dec)
why would anyone want to invest $6,000 in double pane windows,
when a mini-split could handle your heating and cooling,
while costing peanuts to run. While leaving the home as is.
Keep in mind, "The average American moves 11.7 times in a lifetime".
Population Profile of the United States
