Old 02-14-15, 04:37 PM   #1
buffalobillpatrick
Default Arduino R290 Suction Line Superheat Calc.
Some Arduino code that calculates Suction Line Superheat for R290 (propane)
Saturation Temp / Pressure table:
HC-290 (PROPANE) PRESSURE - TEMPERATURE CHART
Must use a Pressure Sensor like this:
http://www.ebay.com/itm/271763798948...%3AMEBIDX%3AIT
Pressure must be between 30 -> 150PSI
Pressure Sensor & Temp sensor are placed close together on Suction Line.
Code:
 * ARDUINO R290 Calculate Suction Line Superheat.
 * Note: REQUIRED SENSOR
 *       Suction Pressure Sensor:  0-150PSI with output of .5 -> 4.5vdc
 * If in DEBUG mode, values are forced to test code function
 * In Void Loop:
 *     , read Suction Temp sensor (analog NTC thermistor)
 *     , read Suction PSI sensor
 *     , convert_raw_sensor_to_PSI
 *     , if input parameter Raw_ADC is not in bounds (between 266 -> 921)
 *     , hang forever1
 *     , Calc_R290_Saturated_Temp
 *     , if input parameter Suction_PSI is not in bounds (between 30 -> 150PSI)
 *     , hang forever2
 *     , calc Suction Superheat
 * Repeat
 * Change History:
 * 02/14/15 Coded, BBP
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
  #else
  #include "WProgram.h"
  #endif
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h>
#define DEBUG 1
//#define DEBUG 0
#define I2C_ADDR    0x3F // <<----- Add your address here.  Find it from I2C Scanner
                       //D3
#define BACKLIGHT_PIN     3  //define LCD digital pins
#define En_pin  2
#define Rw_pin  1             //can't use D0 & D1 Tx, Rx
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5              //can use D2 -> D12 below in code
#define D6_pin  6
#define D7_pin  7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
#define SDA                           A4  //RESERVE I2C for LCD
#define SCL                           A5
//  pinMode(A0, OUTPUT);     //This works acording
                             //  http://arduino.cc/en/Tutorial/AnalogInputPins
//  digitalWrite(A0, HIGH);  //
#define Suct_Temp_sensor_pin      A0
#define Suct_PSI_sensor_pin       A1
float  Raw_ADC, Suct_PSI, Suct_T, Saturated_Temp, Suct_Superheat;
int Y;
void setup(void)       //Start Setup
  pinMode (Suct_Temp_sensor_pin,    INPUT);
  pinMode (Suct_PSI_sensor_pin,     INPUT);
 // Serial.begin(9600); // start serial communication
 // delay(10000);      //time to enable monitor window
 // Serial.println(F("........Hello world!......."));
 // delay(100);
  lcd.begin (16,2); //  <<----- My LCD is 16x2
  lcd.clear();
  //Switch on the backlight
  lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.clear();
  lcd.home (); // go home
  lcd.print(F("R290_SUPERHEAT_1"));
  delay(10000);
  if(DEBUG)
  lcd.clear();
  lcd.print(F("DEBUG = ON"));
  delay(10000);
  else
  lcd.clear();
  lcd.print(F("DEBUG = OFF"));
  delay(10000);
  }    //end setup
  void loop ()
  Suct_T  =  (Read_10K_NTC (Suct_Temp_sensor_pin)); //read Suction Temp sensor
if(DEBUG){ Suct_T = 50;}
  lcd.clear();
  lcd.print(F("SUCT_T="));
  lcd.print(Suct_T);
  lcd.print(F("*F"));
  delay(10000);
   Raw_ADC = analogRead(Suct_PSI_sensor_pin);  //read Suction PSI sensor
if(DEBUG){  Raw_ADC = 400;}
  Suct_PSI = convert_raw_sensor_to_PSI( Raw_ADC);
  lcd.clear();
  lcd.print(F("SUCT_PSI="));
  lcd.print(Suct_PSI);
  delay(10000);
 if (Suct_PSI == -1)  //Suct_PSI is out of bounds
  lcd.clear();
  lcd.print(F("RAW_PSI_NG"));
  lcd.setCursor(0,1);
  lcd.print(F("HANG_FOREVER_1"));
  do{Y = Y;} while (Y == Y);  //hang forever
  else
  {  //else in bounds
  Saturated_Temp = Calc_R290_Saturated_Temp(Suct_PSI);
  lcd.clear();
  lcd.print(F("SAT_T="));
  lcd.print(Saturated_Temp);
  lcd.print(F("*F"));
  delay(10000);
  if (Saturated_Temp == -1)  //Suct_PSI is out of bounds
  lcd.clear();
  lcd.print(F("SUCT_PSI_NG"));
  lcd.setCursor(0,1);
  lcd.print(F("HANG_FOREVER_2"));
  else
  Suct_Superheat = Suct_T - Saturated_Temp;  //calc Suction Superheat
  lcd.clear();
  lcd.print(F("SUPRHEAT="));
  lcd.print(Suct_Superheat);
  lcd.print(F("*F"));
  delay(10000);
  }  //end else in bounds
}  //end forever loop
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
//input parameter Raw_ADC must indicate between 30-150 PSI (266-921)
float convert_raw_sensor_to_PSI(float Raw_ADC)
  //Pressure sensor output .5v = 0PSI, 1.3v = 30PSI, 4.5v = 150PSI
  //analogRead results     .5v = 102,  1.3v = 266,   4.5v = 921
#define PSI_0                    102.0    //ADC of .5v
#define PSI_30                   266.0    //ADC of 1.3v
#define PSI_150                  921.0    //ADC of 4.5v
#define PSI_max                  150.0
float PSI;
  if ((Raw_ADC >= PSI_30) && (Raw_ADC <= PSI_150)) //Bounds check
  // in bounds, continue
   PSI = mapfloat(Raw_ADC, PSI_30, PSI_150, 30.0, 150.0);
   return (PSI);
  }  //end if in bounds
  else {return (-1);}       // error return, out of bounds
}  //end of convert_raw_sensor_to_PSI
//input parameter Suction_PSI must be between 30-150 PSI
float Calc_R290_Saturated_Temp(float Suction_PSI)
#define Array_size            14
//Array element [0]  contains Saturation_Temp *F for 30PSI,
//Array element [1]  contains Saturation_Temp *F for 40PSI,...................>
//Array element [12] contains Saturation_Temp *F for 150PSI,
//Array element [13] contains Saturation_Temp *F for 160PSI
float R290_Saturation_Temp [Array_size] = {7.93, 18.80, 28.42, 36.91, 44.59,
                                           51.63, 58.13, 64.21, 69.90, 75.27,
                                           80.35, 85.18, 89.78, 94.19};
float Val, Next_val, Span, Saturation_Temp, decimals, work;
int I;
  if ((Suction_PSI >= 30.0) && (Suction_PSI <= 150.0)) //Bounds check
  //convert Suction_PSI to array index
  work = ((Suction_PSI - 30.0) / 10.0);
  I = work;                                //drop decimals to get array index
  decimals = work - I; //restore decimals to allow interpolation between array points
  Val = R290_Saturation_Temp[I];           //get array value
  Next_val = R290_Saturation_Temp[I+1];    //get Next array value
  Span = Next_val - Val;                   //Calc Span
  Saturation_Temp = Val + (Span * decimals);//interpolate between array points
  return (Saturation_Temp);
}  // end Calc_R290_Saturated_Temp
int Read_10K_NTC (int which_sensor)
  #define sample_cnt 30
  float alpha =   0.9;     // factor to tune
  float average = 0.0;
  float steinhart;
  int I;
// resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// TEMP. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// The beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3892
// the value of the series resistor
#define SERIESRESISTOR 10000
  for (I=0; I< sample_cnt; I++)
  average =  alpha * analogRead(which_sensor) + (1-alpha) * average;
  delay(10);
  // convert the value to resistance
  average = 1023 / average - 1;
  average = SERIESRESISTOR / average;
  steinhart = average / THERMISTORNOMINAL;     // (R/Ro)
  steinhart = log(steinhart);                  // ln(R/Ro)
  steinhart /= BCOEFFICIENT;                   // 1/B * ln(R/Ro)
  steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
  steinhart = 1.0 / steinhart;                 // Invert
  steinhart -= 273.15;                         // convert to C
  return (round(steinhart * 1.8) + 32);       // round to whole number
                                              // & convert to F
}  // end of Read_10K_NTC
Old 02-14-15, 05:21 PM   #2
BBP, did you write all this? If so, I'm impressed
Now, could there be one written for subcooling which can control an EEV
buffalobillpatrick (02-14-15)
Old 02-14-15, 05:34 PM   #3
buffalobillpatrick
Yep wrote it. Got the idea from BradC post
http://ecorenovator.org/forum/geothe...-gas-gear.html
"I've built the R290 PT Chart into the software, and that pressure sensor is a Carel ratiometric. The LCD gives me the saturated suction temperature (SST), and also the real temperature from the little silver probe (A Dallas DS18B20 digital unit) so I can instantly see the real-time evaporator temperature and superheat. The rotary encoder on the panel allows me full manual control over the EEV, so I can twiddle the knob and observe the effects."
Old 02-14-15, 10:32 PM   #4
Using a pressure sensor is the hard way. All you need are two temperature sensors.
buffalobillpatrick (02-15-15)
Old 02-15-15, 07:39 AM   #5
I wish i had the knowledge to write code but I don't.... yet. I am a programming luddite so it is really hard for me.
BBP, could you write one with 1 thermister instead of the pressure sensor and the thermister? If you want to replicate a standard TXV, one would be enough, no?
I looked on the Fujitsu circuit diagrams and do not see a pressure sensor anywhere, just numerous thermisters. As they are just plug in to the board, I don't know if one or two (or three) are used to control the EEV
Old 02-15-15, 11:31 AM   #6
buffalobillpatrick
NiHaoMike, where would those 2 temp. sensors be placed on a coax evaporator?
See: post #108
http://ecorenovator.org/forum/geothe...html#post39145
Old 02-15-15, 12:00 PM   #7
One on the line between the TXV outlet and heat exchanger, one on the suction line a few inches from the heat exchanger.
Old 02-15-15, 01:01 PM   #8
buffalobillpatrick
NiHaoMike, I don't see how that can work?
That seems to assume that the refrigerant temperature going into the evaporator is exactly the temperature that ALL of the evaporation takes place?
Could't there be some sensible warming of the refrigerant in the input area of evaporator prior to the latient boiling?
Especially with a lot of Subcooling prior to TXV.
Old 02-15-15, 01:15 PM   #9
buffalobillpatrick
Mikesolar, I think that Subcooling would be easy to add & I think that I will work on that next.
I don't know anything about controlling EEV's, I refer to others like BradC. who used a stepper motor.
Old 02-16-15, 09:03 AM   #10
One thing to remember about subcooling as that the action of the valve would be inverse to that of superheat. Where a normal TXV will open in response to a higher SH (bulb temp), the subcooling valve closes in response to a higher SC (or bulb temp).
I will have to look at Brads thread to see if he did any PID control.
