Old 07-08-09, 08:23 AM   #101
jwxr7
jwxr7's Avatar
sunday after the sun went down I reseated all the plug connectors for the DC and the one AC plug. The next day things seemed better, it produced a bit over 1200 whrs. I saw readings near peak inverter output too. Then I saw production #s a little above 1400 whrs for yesterday.
Old 07-08-09, 12:53 PM   #102
Interesting. Perhaps its time for some dielectric grease.
Old 07-09-09, 02:27 PM   #103
groar
X-Frenchy: very
groar's Avatar
Originally Posted by jwxr7 View Post
I'm not sure what you mean by ? Is 11 and 15 the time, like between 11 am and 3 pm?
Yes, I always forget that some people have 2x12 hours per day
I remember one day feeling the panels with my hand. They were extremely hot. Aren't the polycrystalline type like mine effected more by temperatue? I also felt the inverter and it wasn't too bad.
All solar panels are sensible to heat. Generally the lower the efficiency and the higher the loss of production because the panel is bigger so it receives more heat. Amorphous, polycrystalline and monocrystalline have different loss coefficient per °C. Mine are at 0.4%/°C. Monocrystalline have a lower coefficient while amorphous have a higher one. Last each panel loose power in time. Mine are guaranteed to have 80% of their initial power after 25 years. Amorphous can loose 20% in the first year then "stabilize" (ie loose "only" a couple % per year next). Best monocrystalline can loose very few power. Don't forget the important temperature is the one of the panels which are rated at 15°C (77°F). At 35°C (95°C) ambient, the panels can be at 75°C (167°C).
In such conditions my panels are loosing 18% : (1-0,4%)^(75-25) = 0.818. Today was rather cool and between clouds was produced a sustained 2.2kW. During last cloud-less day, was produced at most a sustained 1.85kW.
The suns path thru the sky is actually quite far north in the morning and evening too. Making me want to angle my array that way slightly, or at least go totally flat. They seem to recommend this for lower lattitudes, but not mine.
Recommendations are generally for a fixed position all year long with a goal of having the max production over all the year, or the max production during the worst months. You may try to turn the panel to East with a low incline so you get a maximum of power when the temperature is lower. From the region, I can see that the systems producing more are those turned a little to the East as they are producing sooner and more in the morning.
Denis.
    (2.66 kg/l diesel)
    (59.1 g/kWh)
Old 08-04-09, 09:09 PM   #104
gascort
regarding the input voltage, according to the Enphase website, http://www.solarpanelstore.com/pdf/E...reliminary.pdf
it says "peak power tracking voltage 22-40V"
Are you still using 12V input into your inverter? Can you put 14-15V into it?
Thanks.b
Old 08-06-09, 06:41 AM   #105
jwxr7
jwxr7's Avatar
Thanks.b
That is for an m190 inverter .
That's not what I'm using. My solar array has four 12volt panels wired in series for a nominal voltage of 48v. I guess I may never have described some of that info, sorry.
Old 08-06-09, 06:43 AM   #106
jwxr7
jwxr7's Avatar
I haven't posted july production #s yet, but I remember them averaging about 1kwhr/day. I'll try to get more specific #s soon.
Old 09-03-09, 02:37 PM   #107
jwxr7
jwxr7's Avatar
I had a chance to see my meter run backwards the other day. I was getting ready to go on vacation so I had everything off or unplugged except a few things. When the fridge was running the solar panels (in full sun) would make just enough power to cancel it out. When the fridge stopped running the meter cruised nicely in the other direction .
Old 09-03-09, 02:39 PM   #108
MetroMPG
Infrequent noob
Congrats, Jamie. That's a milestone worth noting.
Old 09-03-09, 02:58 PM   #109
Wooohoo, thats really cool.
Old 09-04-09, 07:08 AM   #110
jwxr7
jwxr7's Avatar
Here are some production #s.
For July 30 kwhrs were produced averaging 968 whrs per day. This includes the first week when I was having unusually low production due to a suspected bad connection.
For August 28 kwhrs were made averaging 903 whrs per day. This month had many rainy days that hurt the numbers.
electric, solar
