Old 12-21-09, 02:09 PM   #21
NeilBlanchard
NeilBlanchard's Avatar
Yes, it would be fairly simple (I think?) to put the output heat coils of a refrigerator down through the floor so the heat could be more easily shed in the cooler basement/crawlspace.
Old 12-21-09, 03:06 PM   #22
In the winter, you might want to keep that heat in the kitchen.
But in the summer, maybe a small vent above the back end of the refrige?
Let the heat draft up into the attic.?.
Moving those coils around isn't real simple. Check out AC_Hacker's posts and see.
Old 04-19-14, 06:45 AM   #23
cbearden
dremd,
I know this is an old thread. But I was curious if you ever made any progress on this? I'm planning on installing my own gshp system and I'm also hoping to be able to use cooling as well as heating using this system.
cbearden is offline   Reply With Quote
Old 04-19-14, 07:44 AM   #24
It is five years old..
My dream of buying a "24KHS72 - Sanyo 24,200 BTU Heat Pump Air Conditioner Kit", actually worked out pretty well..
Heck, in another five years, I might be able to get one that works down to -20 deg F..
If the current global warming trend continues, it would be a very useful heating system to own..
Old 04-19-14, 07:13 PM   #25
Plenty. Start here:
http://ecorenovator.org/forum/geothe...shp-build.html
http://ecorenovator.org/forum/geothe...-pressure.html
http://ecorenovator.org/forum/geothe...source-hp.html
http://ecorenovator.org/forum/geothe...ging-gshp.html
And of course, the manifesto thread (pace yourself).
Old 04-19-14, 07:17 PM   #26
Crash / Intro Course in water2water heat pump systems:
http://www.climatemaster.com/downloads/CA226.pdf
They can be done. They can be done DIY cheaply. They can perform very well for decades if done right the first time. Note: done right doesn't have to mean super-expensive unless you are lazy. Substitute money for sweat and time to fit your need and skill level.
