Old 04-04-14, 10:48 AM   #1
sandiegolloyd
Default Solar PV Panel on top of Solar Thermal Panel
I am designing and installing a Solar PV Panel System for my south facing roof. Can I put the Solar PV panels directly over my Solar thermal panels (six inches above) and not impact the efficiency of the thermal panels too much? Roof is south facing and I use my thermal panels to heat my pool Thanks.
sandiegolloyd is offline   Reply With Quote
Old 04-04-14, 05:11 PM   #2
Exeric
I wouldn't count on it for one second. Just common sense says you'll be shading the solar thermal panels from direct infrared radiation of solar thermal energy. Plus, which is equally important, if you do it you'll be giving all of us fellow Californians a bad name.
Exeric is offline   Reply With Quote
Old 04-04-14, 06:26 PM   #3
where2
DIY Geek
Pool panels, NO.
If you want to heat domestic hot water, there are devices to do that... SunDrum Solar makes a back plate for some PV panels to heat water while the panels generate electricity. Last time I checked, each back plate was around $800.
