Old 02-04-14, 01:30 PM   #1
brogsie
Default Temperature of mini split
I was checking the heat that comes out of my Fujitsu mini split with an IR gun. To my surprise it only measured 78*-79*. I thought it would be hotter. I tried a few time with the same results. It was about 20* outside. It keeps the house nice and warm. Any one else measure the temp from their mini split?
Old 02-04-14, 01:58 PM   #2
It is 40 deg here the LG units are putting out 120 deg and the Gree is putting out 119 deg.
brogsie (02-04-14)
Old 02-05-14, 06:41 AM   #3
brogsie
I rechecked the temp of the mini again. This time I shot the IR gun up inside instead of from 5 feet away. The temp was 95*-100*. 30* outside. I wonder if that's the right temp. It keeps the house plenty warm but takes a little while to heat up when turned up.
Old 02-05-14, 08:25 AM   #4
Then it's probably "right sized" when you're used to "oversized" units.
brogsie (02-05-14)
Old 02-05-14, 08:33 AM   #5
I was shooting the IR into the mini split maybe 3 foot away. If you have a inverter model it will ramp up and down based on what it needs to do.
brogsie (02-05-14)
Old 02-05-14, 09:34 AM   #6
nokiasixteth
Ill check mine once i finish installing it . Just waiting to get a vac pump and finish runnin wire
it says inverter so im guessin it will vary
Old 02-05-14, 09:55 AM   #7
What brand and model did you get?
Old 02-05-14, 10:05 AM   #8
nokiasixteth
I bought that el cheapo 17 seer kozy kool i had seen. I figure if i get 2 or 3 years out of it it i will be happy and it will have paid for itself. But if it last longer thats perfectly fine with me .Plan on later on buying a quad zone for the whole house once the money tree gets big.
Old 02-05-14, 10:25 AM   #9
What model how many BTU’s
Old 02-05-14, 10:31 AM   #10
nokiasixteth
Brand is Kozykool
Model is 12HRDN1
It is 12,000 btu cooling and 13000 btu heating.
Has the toshiba compressor ive always had good luck with toshiba . Weather or not its a dud . Only time will tell.
