06-04-15, 03:18 PM | #10 | ||
They are quite like what you describe except that a heater is used to make the wax expand and actuate the valve. Therefore every open valve draws some 5W (seems the most popular value).
The plan for the moment is to use the best possible insulation of the foundation; put thick insulation directly onto the ground and pour the concrete foundation (including heating) on top of this. Hopefully this will work in the location we have found, depends on soil conditions. Some form of control will be needed and used but the story you tell is another reminder to adhere to the KISS principle. Cheers, Marc |
Tags |
air conditioner, diy, gshp, heat pump, homemade |
