Old 05-13-13, 06:41 AM   #11
razor02097
Originally Posted by jlaw View Post
I used a Honeywell VisionPro IAQ 7 day programmable on my split system heat pump with propane backup. This T-stat solved numerous problems for me. I installed the outside temp sensor, get rid of the mechanical temp sensor most times mounted on outside unit. It permits me to adjust my outside temp cutoff and also lets me monitor the outside temp on the T-stat. Allows control of humidifier, air cleaner and more. A great all in one thermostat.
VisionPRO IAQ | 7-Day Programmable Thermostat Comfort System
All-In-One Control - Controls temperature and Indoor Air Quality (IAQ) products such as humidification, dehumidification, ventilation, and air filtration monitoring - all from a single control in the living space
7-Day Programming - Allows separate programming for each day
Touchscreen Interaction - Easy-to-follow menu-driven operation simplifies programming by responding to your choices
Smart Change/Check Reminders - Let you know when to service or replace filters, UV bulbs (based on actual usage) and humidifier pads
Energy Savings - Program to save up to 33% on annual heating and cooling costs (If used as directed. Savings may vary depending on geographic region and usage)
Whole-House Telephone Access - Works with your existing telephone line to offer control of your home's temperature and Indoor Air Quality over the phone
Model Numbers - YTH9421C1010, YTH9421C1002, TH9421C1004
5-Year Warranty
Exactly what I was looking for
Thank you so much!
razor02097 is offline   Reply With Quote
Old 05-13-13, 08:46 AM   #12
I used a Honeywell VisionPro IAQ 7 day programmable on my split system...
Honeywell YTH9421C1010... List Price = $556.34
Honeywell YTH9421C1002... List Price = $516.58
Honeywell TH9421C1004... List Price = $412.10
Best,
Old 05-13-13, 08:55 AM   #13
razor02097
Amazon has YTH9421C1002 for $182
Honeywell YTH9421C1002 Visionpro IAQ Touch Screen 7-Day Programmable Thermostat, Version 2 - Amazon.com
It sounds promising
Old 06-26-13, 02:49 PM   #14
Any updates? Did you buy one? How is it working?
Old 07-31-13, 06:41 AM   #15
razor02097
I did buy one and have been using it for a week now. I found one from a seller on Amazon for $97. It was new but the box was a little ratty.
As far as savings so far... There really haven't been any noticeable changes in the kW/hr meter. However I am still tweaking the settings and the house is noticeably cooler. The old thermostat was the lever style so it was nigh impossible to get a proper reading. I use an app on my phone called ECAS to keep track of my meter. According to the data I can keep the thermostat cooler in the summer and still use the same amount of electricity... Plus I don't have to mess with the thermostat anymore.
I also called out the pros to tune up my system. That did make a difference. I don't know the history of the system but from what the neighbors told me it is likely that it hadn't been touched in something like 5 years...
Old 12-03-13, 12:36 PM   #16
razor02097
I wanted to give another update... Well as soon as the cold snap hit here my electric bill doubled... Turns out the thermostat is very impatient. What I mean is it will kick on the aux heat during the "recovery" period. The recovery period is the time when my thermostat changes from "Away" to "Return" and start to heat up the house.
Well for $24 I bought a temp sensor to mount outside so I can set lockouts. The sensor is a "Honeywell C7089U1006 Outdoor Temperature Sensor" So far so good. I was able to set the heat pump lockout at 30* F so it won't kick on below that threshold. I set the aux heat lockout for 35*F so the aux heat won't kick on unless below 35*. This way I'm hoping the heat pump will be used for recovery instead of the resistive elements the furnace has.
A little more info on my system... The heat pump is a 12 year old 10 seer Rheem unit. Last measurement comparing return to register was +18*F. The aux heat is four 30 amp resistive heat banks which will set your hair on fire given the chance... I also have a Rheem whole house humidifier attached to the furnace.
I'll update as soon as I have a few weeks of data. Hopefully I can save some monies while squeezing some more use out of HVAC relics I currently own.
