Old 02-06-12, 06:08 PM   #11
We've been taking a nice walk just about every afternoon. On the way back home today,
I was getting warmed up and had unzipped my jacket and removed my gloves..
But, I was still amazed to see people out walking dogs and jogging, while wearing shorts!!
Since Nov 1, 2011, until today, the average temp here has been 37.9 °F..
During that same 97 day time span last year (2010-2011) it was 30.7 °F!
7 °F warmer makes a difference in the heating bills...
Climatological Data
I was in Sears today and they have a ton of 28" snowblowers on the floor..
Just like mine! (still un-used) I should have waited for the big sale!!!
Old 02-07-12, 09:14 AM   #12
PaleMelanesian
PaleMelanesian's Avatar
I just got my January electric bill. It's a laughable 2/3 of my previous record low. I attribute equal portions of that to the weather and the new high-efficiency heat pump.
Old 02-07-12, 10:08 AM   #13
Default La Niña ??
2011 - 2012 - 2013 - El Nino La Nina Forecast and Predictions
It seems like La Niña (or maybe CO2) and high-efficiency heat pumps are a winning combo!!
Whereas we are breaking power usage records here..
Since this is our first season:
A. Running two Sanyo 24k systems.
B. Heating the den (w/ it's 100 sq feet of glass).
C. Keeping both systems set to 20 to 21C 24-7.
D. Being so old that I need to feel warmer.
So, we are creating a new benchmark this winter..
If it's colder or warmer next year, we can compare kWh used..
Unless, we decide to run at 21-22C next season!!
Old 02-07-12, 04:56 PM   #14
PaleMelanesian
Correction: It's even better than the 2/3 I said.
Compared to the previous 3 Januaries, both Heating Degree Days and kWh/hdd are about 70%. Actual kWh used is about 50% of the previous average.
At least I was correct in my guess of 50/50 benefit from each.
Old 02-23-12, 12:28 PM   #15
Solar
i should get graphing software, anyone have suggestions?
My Climate Change Blog
Global Warming News - The Global Warming Times - Videos, Science, Solutions, Activism
Solar is offline   Reply With Quote
Old 02-24-12, 07:05 AM   #16
Solar
mine is about half, becuase i moved into an apartment where my utilities are included, so its actually alot less because I can actually turn on the heat to reasonable without paying a 600$ heating bill, not to mention my last place was so cold from air leaks and a 30 or 40 year old heating system blown in air vs my new place radiators(much safer, less dry, no mold trapped in vents)
Old 02-24-12, 07:09 AM   #17
Solar
Climatological Data
its snowing here now, maybe you can use the snowblower u bought to clear off your lawn.
Old 02-24-12, 08:15 AM   #18
PaleMelanesian
I use Excel.
Old 04-09-12, 09:56 AM   #19
Default Summer was here last month.. For 6 days..
I hope that little 6 days of summer isn't all we get this year..
Because, we are still running the heat up here in New England.
Now that home heating oil cost has skyrocketed over $4 a gallon,
some of my neighbors are getting slammed with very large oil bills.
At that rate, it's costing us $2 a day to heat our hot water with oil..
But for space heating, the Sanyos are saving our bacon again this month.
(Averaging in low 40s F) Now using about 10 kwh a day. ($1.68)
Edit: Got some warm peaks this spring(2014), but not real impressive..
ID:	2254   Click image for larger version
Old 04-09-12, 02:02 PM   #20
PaleMelanesian
My march bill was HIGHER than last year. The AC ran a few times. We had the most Cooling Degree Days ever (for march), but the 2nd lowest March bill thanks to the new central system. It seems a little high, still.
