Old 10-01-10, 11:12 AM   #1
Default Toronto's new green roof law a first for North America
The quote pretty much sums it up. I wonder how this is going over with the locals and builders?
In a first for a North American city, Toronto recently passed a new law mandating "green" rooftops for all new developments. Any new construction with floorspace of more than 2,000 square meters must devote between 20 and 60 percent of its roof to vegetation. The rule applies to residential, commercial, industrial and institutional structures.
Toronto's new green roof law a first for North America | MNN - Mother Nature Network
Old 10-01-10, 12:43 PM   #2
gasstingy
Affects structures 2,000 square meters and larger. Let's hope not many residences are affected!
Old 10-01-10, 06:23 PM   #3
Christ
Why would we hope that?
It's not much more difficult to build a green roof than it is to lay a normal one, except it's much more beneficial.
Green Roof vegetation can include any type of moss covering, which generally are fairly lightweight and don't require a large amount of dirt, meaning that even existing roofs can be converted without much cost.
Old 10-04-10, 09:34 AM   #4
gasstingy
Because 1 square meter is more than 9 square feet. So a residence over 2,000 square meters is over 18,000 square feet. That's about 12 times the size of my 1,500 sf home.
Old 10-04-10, 02:42 PM   #5
Christ
Ah, see, I missed the intent of your post.
I presumed you were alluding to the law being changed to include smaller buildings, which would then affect housing.
In that light, it seems like you're opposed to the law, but now I see what you meant.
Old 10-06-10, 12:01 PM   #6
Phantom
Phantom's Avatar
Sounds great I plan on having a green roof and have talked about trying to get NKU my university to add one.
Old 10-06-10, 01:51 PM   #7
strider3700
does anyone have any links to sites discussing the requirements on retrofits of green roofs? I have a flat tar and gravel garage roof that needs replaced but I'm not sure if a light weight green roof would be an option without major restructuring to support the load.
Old 10-06-10, 02:59 PM   #8
benpope
benpope's Avatar
This may be a good place to start: DIY Green Roof System
The units that they are talking about there are 2' x 2' x 4" and weigh 15 lbs when watered.
Old 10-06-10, 06:45 PM   #9
strider3700
cool but one correction.
They are 15 pounds per sqft so 60 pounds per unit.
At 15 pounds per unit removing the tar and gravel and replacing it with a torch down and this would be about the same weight or maybe even less. At 15 per sqft I think I still need to restructure. I showed the idea to my wife and said what about wild flowers? and she loved the idea enough to have me look into prices.
Obviously I've got some more research to do.
Old 10-07-10, 06:33 PM   #10
Whatever it is, I'd make sure its low maintenance unless you have easy access to the area.
Definitely let us know how it goes though!
