Old 04-23-14, 03:42 PM   #251
ButchDeal
Originally Posted by Vern2 View Post
TED Home Pro is sending out another MTU to add solar. I'll be able to have my kWh numbers all on one screen. With the Spyder, break out, cloth dryer, hot water, shop (2 ton heat pump, welders, Air compressor, plasma, spot welder) as one number, Volt charge and house 5 ton heat pump.
Have you thought of using pvoutput.org. I have my TED5000 set up going to post data there and gives great graphs, compares to pvwatts predictions, compares to other systems output as well.
ButchDeal is offline   Reply With Quote
Old 04-23-14, 03:48 PM   #252
I don’t have data from my TED going there but I do have Enphase data going there.
Flynns Arcade 12.560kW
Give use a link to yours do you have solar power? Tell use about it.
Mark
Old 04-23-14, 03:57 PM   #253
ButchDeal
Mark
Yes I do. it will not let me post the URL yet but this is my systems:
list.jsp?p=0&id=31117&sid=28507&v=3&s=1
it is a self install with limited electrician contracted. Outback Flexpower One, with step up transformer for the well (220V), self built battery box with fan less vent, and 3kW of panels. We had record snow and cold weather in January but even so almost to 1MWh for the year.
Old 04-23-14, 04:08 PM   #254
Nice here is your system link
RealDeal 3.000kW
Are you on net metering?
Old 04-23-14, 04:22 PM   #255
ButchDeal
Yes. We have net metering in WV though no other incentives and my house is 100% electric. I upgraded the heat pump to high efficiency model just 4 years ago
Old 04-30-14, 11:29 PM   #256
We had our best month so far 1,827 KWh.
We will carry forward about 750 KWh I sure wish they would not zero use out June 1.
(they don't pay us for extra power on that date)
This would cover one of my winter months. The power company says they are still working on changing the zero out date.
Other solar guys what did you end up with this month?
ID:	4364   Click image for larger version
Old 05-01-14, 07:18 PM   #257
where2
DIY Geek
602kWh from a 4.4kW system. Best panel = 31.2kWh, Worst panel = 26.7kWh. Average per panel = 30.1kWh.
Old 05-01-14, 07:45 PM   #258
Nice numbers. Is that your best month so far?
Old 05-01-14, 08:08 PM   #259
where2
DIY Geek
Not quite, I actually gathered 603kWh in August 2013, the same month my net meter was installed. (Net meter was installed at ~10AM on August 1st) I missed more than 7kWh that morning, since I didn't throw the breakers to bring the system online until ~12:30pm.
My best day, to date, is a 25.7kWh day in March.
Old 05-02-14, 10:33 PM   #260
"We had our best month so far 1,827 KWh."
That's amazing. That's more than I used for the entire year in 2012!
