Old 01-19-09, 01:13 PM   #21
jwxr7
jwxr7's Avatar
I need to check mine for snow more often.
I've thought about using the pole mount for my big old satellite dish. I could reuse the linear actuator and come up with some sort of active tracking system. The pole is already in the same area as my pv set-up.
On friday I pulled over 1200whrs from the sun . That's over 6 hours of full inverter output. I need more days like that .
jwxr7 is offline   Reply With Quote
Old 01-19-09, 01:20 PM   #22
Wow very nice. How many times did you adjust it on Friday?
Old 01-19-09, 02:24 PM   #23
jwxr7
jwxr7's Avatar
I don't adjust mine other than seasonally, so that was a fixed rack production #.
Old 01-19-09, 02:31 PM   #24
jwxr7
jwxr7's Avatar
Originally Posted by MetroMPG View Post
But it's sobering to realize how small a fraction of total power usage it is.
I think the general public vastly overestimates the power production capabilities of solar, if the number of people who suggest I power the electric car with PV is any indication. They need to see a thread like this to get a better idea.
Very true. On a good sunny day you might offset the power used by accessories . Plus these panels are fairly heavy and large, so it would be impractical to have on a moving car. They could mount on a full size truck over the bed or on a big stationwagon's roof, but not a metro .
Old 01-19-09, 07:04 PM   #25
james
Yes, people don't really think about how much energy is used to move a car down the road. You'd have to be a rich man to do it with solar power. Lights, stereo, and computer use very little by comparison.
james is offline   Reply With Quote
Old 01-21-09, 07:08 AM   #26
jwxr7
jwxr7's Avatar
here's a summary of the last 7 days production from january 14th thru the 20th;
wed, 40 whrs
thurs, 560 whrs
friday, 1280 whrs
sat, 140 whrs
sun, 440 whrs
mon, 1060 whrs
tues, 1300 whrs
Old 01-21-09, 07:28 AM   #27
Those numbers are looking pretty darn good. Almost 700 Wh a day from such a small setup!
Old 01-21-09, 12:58 PM   #28
dogbreath
OK gang- does anyone know of a pv for newbies resource? Tons of ignorance needing to be modified to slight knowledge. Thx
dogbreath is offline   Reply With Quote
Old 01-21-09, 01:47 PM   #29
If I were you, I'd start here:
Solar Photovoltaic Projects
Old 01-21-09, 08:07 PM   #30
dogbreath
Thanks Daox, exactly what I needed.
electric, solar
