Old 08-11-14, 12:31 AM   #1
Geo NR Gee
Default Concentrated Solar power with adaptive technology
Saw this tonight. Seems pretty interesting....
Adaptive Material Could Cut the Cost of Solar in Half
A new material, combined with a cheap tracking system, could unleash the promise of concentrated solar power.
By Kevin Bullis on July 30, 2014
WHY IT MATTERS
Cheaper solar power would help address climate change.
Sun tracker: Small lenses focus sunlight onto an adaptive material that helps track the movement of the sun.
A material with optical properties that change to help it capture more incoming sunlight could cut the cost of solar power in half, according to Glint Photonics, a startup recently funded by the Advanced Research Projects Agency for Energy (ARPA-E).
Glint’s adaptive material greatly reduces the cost of a tracking system used in some types of solar power. It changes its reflectivity in response to heat from concentrated sunlight in a way that makes it possible capture light coming in at different angles throughout the day.
It’s well known that focusing sunlight makes it possible to use smaller, cheaper solar cells. But this is usually done with lenses or mirrors, which must be moved precisely as the sun advances across the sky to ensure that concentrated sunlight remains focused on the cells. The equipment required for that and the large amount of steel and concrete needed to keep the apparatus steady makes the approach expensive.
Glint’s light concentrator has two parts. The first is an array of thin, inexpensive lenses that concentrate sunlight. The second is a sheet of glass that serves to concentrate that light more—up to 500 times—as light gathered over its surface is concentrated at its edges.
The sheet of glass is covered with reflective materials on the front and the back that trap light inside the glass. One of these sides features the new adaptive substance made by Glint. When a beam of concentrated light from the array of lenses hits the material, it heats up part of it, causing that part to stop being reflective, which in turn allows light to enter the glass sheet. The material remains reflective everywhere else, helping to trap that light inside the glass—and the light bounces around until it reaches the thin edge of the glass, where a small solar cell is mounted to generate electricity.
As the day goes on, the beam of light from the lenses moves and the material adapts, always allowing light in only where the beam of light falls, and reducing the need to keep the apparatus pointed directly at the sun.
Glint’s CEO Peter Kozodoy says solar power from its devices could cost four cents per kilowatt-hour, compared to eight cents per kilowatt-hour for the best conventional solar panels. This month, the company received the first installments of a $2.2 million grant from ARPA-E. The ARPA-E funding will allow the company to scale up from prototypes just 2.5 centimeters across to make 30-centimeter modules, nearly large enough for commercial operation.
Howard Branz, a program director at ARPA-E, says the main remaining challenge is increasing the amount of sunlight that makes it to the solar cells, something that needs to be improved over the proof-of-concept device, in which some of the light is absorbed or reflected en route to the solar cells.
Gain the insight you need on emerging technologies at EmTech MIT.
Register today
Old 12-28-14, 02:46 PM   #2
frazelle09
World peace is inevitable
frazelle09's Avatar
Thanks for posting this great article! There's so much research and invention going on in the solar arena. It's a great time to be alive in many respects.
Have a wonderful afternoon!
"The earth is one country and mankind its citizens."
Bahá'u'lláh
"La tierra es un sólo país y la humanidad sus ciudadanos."
frazelle09 is offline   Reply With Quote
Old 12-28-14, 08:04 PM   #3
Geo NR Gee
Your'e welcome. I wonder what I have around the shop to help collect the sun and focus it for a smaller scale household size collector unit???? I think I will search for what you can do with used satellite antenna's.
Old 12-28-14, 08:05 PM   #4
frazelle09
frazelle09's Avatar
Sounds great. Let us know what you come up with!
Have a super evening!
Bahá'u'lláh
