07-04-11, 08:50 AM | #821 |
Renovator-in-planning
digging
Randen,
Did "you" dig it up? or did you have someone do it? I'm trying to get an idea what a backhoe should cost to dig some ditches... Thanks Seth |
07-04-11, 09:39 AM | #822 | |||||
So, do you have any details (and photos?) on how you welded your HDPE manifold? Using my home-built HDPE welder, I was only able to do butt welds... sounds like you probably rented some socket welding gear. If that is the case, I have never done socket welding and I'd really like to know how it went for you. Quote:
It may take a year or two for the earth to completely settle into place around your slinky tubing and for you to have the full capacity of your loop field available. It's been an interesting adventure for me to find inexpensive HX's that I can use for a GSHP. I don't know if you are in a position to be able to buy properly-sized new ones from a vendor. That would be the simplest but most expensive way to go. Vendors should have technically trained staff that can match the right hardware to your needs. If you're gonna go with used or economy HXs, the adventure begins... Previously in the thread, I tried to clarify for myself, and for the 'manifesto' readers how this might be done. But briefly:
I also noticed that in spite of all my efforts to keep all the HDPE clean inside, that some debris was flushed out, along with the trapped air. Since the galley ways in the brazed plate HX's are pretty small, you want to get ALL the debris and crud out of the lines. And as a final consideration, if you can get or make distilled water for your loop field final fill, your brazed plate HX's will have virtually no fouling. And don't worry about burdening us with too many photos... there's no such thing. Best Regards, -AC_Hacker
I'm not an HVAC technician. In fact, I'm barely even a hacker... Last edited by AC_Hacker; 07-04-11 at 10:04 AM.. |
07-05-11, 06:37 AM | #823 |
Uber EcoRenovator
Pachai
Did "you" dig it up? or did you have someone do it? I'm trying to get an idea what a backhoe should cost to dig some ditches... No can't take the credit for the digging. Hired a contractor I haven't received a bill yet but I did ask them to bring their largest machine even then it took 8 hrs to dig and about 6 hrs to back-fill @$160.00/hr $2200.00 Plus a contractor to weld the tubing 6 hrs (he also helped rolling out the tube)Plus the cost of the tubing and fittings maybe about $3500.00 all together or the cost of propane for one seasons heating. I may add that the loop we had installed for the house was $8000.00 OUCH. But after the 2nd heating season it's half paid for itself. You may just call some of your local contractors and have them over to look at your project and provide you with a quote. Randen |
07-05-11, 04:24 PM | #824 |
Uber EcoRenovator
AC Hacker wrote:
So, do you have any details (and photos?) on how you welded your HDPE manifold? Using my home-built HDPE welder, I was only able to do butt welds... I'm sorry I didn't get any photos for the tube welding. You are right the pin and socket welding is very cool, heat both the internal/external of the fittings to becoming very soft and slide together. With the right tools, easy. It did require two persons. I'm totaly amazed with anyone that can turn a George Forman grill into a tube welder. I'm in the tool & die business and after 10 hrs a day in-front of a machine I don't like making something I can borrow or rent after all who needs the practice. Now converting the a/c unit into a GSHP that looks like fun. "One mans junk is our treasure." Machining a valve that dosen't already exsist. Brazing some tubes and a little wiring to save about $5000.00 I'm in. I will post more on the valve as its perfected. The heat exchangers will be a little oversized, better that, then lose some efficiency. The cap tubes I have, but would the DXV valve be a good investment?? We are currently plumbing the loop into the air-handler to see if cooling the shop can occure without the heat-pump. I will post the results soon. Temps now about 34 deg.C or 95 deg. F out-side here. I was going to try the circ. pump for purging. Thanks for the heads up we'll employ a larger pump. Thanks Randen |
07-06-11, 01:02 AM | #825 | ||
...also, if you shop around, you can pick one up pretty cheap. You will need to know the refrigerant type... (TXVs meant for R-22 will also work for R-R290 (propane)). Otherwise, get a TXV that is specified for your desired refrigerant. You'll also need to know the capacity of your system... in your case that would be 3.5 Tons. Also, your cap tube(s) are specific for your refrigerant, again, R-22 cap tubes are very close to those required for R-290. Other refrigerants will need a cap tube length and ID combo, specific for the refrigerant you choose. And your cap tube(s) I guess there were maybe three (possibly four) of them, will come together in a header... they were probably that way in your AC... if you were careful, you cut the tube a few inches (at least) above where the cap tubes were brazed, an you won't have to re-fabricate that header part. That tube where the cap tubes connect will attach to the 'out' part of the TVX. Yeah, making your own heat pump is interesting, for sure... Have you lined up a vacuum pump? Regards, AC_Hacker
I'm not an HVAC technician. In fact, I'm barely even a hacker... Last edited by AC_Hacker; 07-06-11 at 01:08 AM.. |
07-06-11, 03:57 PM | #826 | |
I got the first quote - 150' of trench, 6-8' deep, 3' wide. With shoulders for trench safety. $7600. Removal of old driveway 100' $1800. It's a tight lot, so it will actually be 3 digs. dig, put dirt on side. Put in pipes. Backfill with dirt from second trench. Repeat for 3rd then backfill last trench with original dirt. It seems a bit high....but it is a basis for comparison when I ask the current GC for a quote. Everything there seems to be $$$$. (The current GC is bringing in a backhoe to take out the old driveway, so it might be le$$.) |
07-06-11, 07:06 PM | #827 |
randen, pachai & 'The master plan',
This is all so great, Summertime and so much earthwork going on! randen & pachai, I don't know if you have peeked in on what's happening on another thread by 'The master plan', but he has it going on too, with photos of his slinky coils about to get buried... He's going with a ground temp circulator only... He's a little hesitant to hack an air conditioner, but then the earthwork is the most formidable part of the project. To my way of thinking, hacking the heat pump is dessert. Best Regards, -AC_Hacker
07-06-11, 08:08 PM | #828 | |
I'm busy moving a laundry sink where a window became a doorway - learning to sweat solder, etc. Giovani laid tile in the kitchen today, so the cabinets should go in by the weekend.... so I should get my workshop (cabinet store room) any day now... Then I can hope to take apart some AC units in my excessively copious free time. (Solar guys called today to check the roof :-) :-) |
07-06-11, 09:35 PM | #829 |
pachei,
Sorry had a stroke. I'm keeping up with most guys with half a brain. Somethings are still difficult, and comes from left base.Introduction
Vern To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by Vern2; 07-06-11 at 09:40 PM.. |
07-07-11, 12:03 AM | #830 |
Towel Bar
I had the plumber leave me the option of adding a heated towel bar to compliment my radiant floor.
I was thinking along the lines of what Radiantec suggests here http://www.radiantec.com/pdf/Install...towel_rack.pdf But I have a question for those who know about various plumbing fixtures, etc. Can I use pipe that is more attractive than copper? eg, stainless? (expensive) bronzed brass? (is it available?) (Chrome 24" is $35 as opposed to $12 for 10' copper) My thought if I used regular threaded pipe would be to use regular threaded elbows to match, stub it into the wall cavity, and then adapt it to the 1/2" PEX. Or, I could just use copper and spray paint it to match the Delta Oil Brushed Bronze... recommendations appreciated Seth PS it's Way Off Topic, but....we bought a mirror for the Master Bath and THEN thought about a medicine cabinet. No Worries, the Internet is great. I can build a medicine cabinet for this large mirror.... Last edited by pachai; 07-07-11 at 09:25 AM.. |
Tags |
