Old 03-02-13, 05:34 PM   #1
Default Arduino issues
OK, even though Arduino is supposed to make us older farts equal to the young dudes in programming, I will readily admit that I am useless at it which is even more embarrassing as I was an electronics technologist 30 years ago. ARRRGGGG.
So all I am trying to do is take the Mega, and sensor shield, add a 10k thermister (2 wire, not the digital stuff that I never see in the heating industry) and see the temp change on the screen.
I followed a thread on yourduino to do this and got errors that I cannot explain and it seems, I cannot even find definitions to some of the phrases given at the bottom of the page when trying to verify the program.
Here is an example:
"was not declared in this scope"
What does that mean? I cannot find a glossary of terms used anywhere. HHHheeeellllpppp (please)
Old 03-03-13, 01:35 AM   #2
RobbMeeX
Eco OWNER!!
I am no pro, but is this regarding a variable that was not declared initially? Do you want to post up your sketch?
In it for the money (savings)
Old 03-03-13, 06:10 AM   #3
The sketch is not important so here only because it it taken directly from the the adafruit book about how to use a thermister. I cut and paste the exact sketch from the site and voila......errors.
The phrasing doesn't have enough explanation. Here is what i tried to do:
Code:
// the value of the 'other' resistor
#define SERIESRESISTOR 10000
// What pin to connect the sensor to
#define THERMISTORPIN A0
void setup(void) {
  Serial.begin(9600);
void loop(void) {
  float reading;
  reading = analogRead(THERMISTORPIN);
  Serial.print("Analog reading ");
  Serial.println(reading);
  // convert the value to resistance
  reading = (1023 / reading)  - 1;
  reading = SERIESRESISTOR / reading;
  Serial.print("Thermistor resistance ");
  delay(1000);
This works well enough. What I get is the thermister value which changes as it should.
Then I erase this program and copy one that changes the thermister value to deg C (below) and it doesn't recognize the thermister.
Code:
// which analog pin to connect
// resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// temp. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// how many samples to take and average, more takes longer
// but is more 'smooth'
#define NUMSAMPLES 5
// The beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3950
int samples[NUMSAMPLES];
void setup(void) {
  Serial.begin(9600);
  analogReference(EXTERNAL);
void loop(void) {
  uint8_t i;
  float average;
  // take N samples in a row, with a slight delay
  for (i=0; i< NUMSAMPLES; i++) {
   samples[i] = analogRead(THERMISTORPIN);
   delay(10);
  // average all the samples out
  average = 0;
     average += samples[i];
  average /= NUMSAMPLES;
  Serial.print("Average analog reading ");
  Serial.println(average);
  average = 1023 / average - 1;
  average = SERIESRESISTOR / average;
  float steinhart;
  steinhart = average / THERMISTORNOMINAL;     // (R/Ro)
  steinhart = log(steinhart);                  // ln(R/Ro)
  steinhart /= BCOEFFICIENT;                   // 1/B * ln(R/Ro)
  steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
  steinhart = 1.0 / steinhart;                 // Invert
  steinhart -= 273.15;                         // convert to C
  Serial.print("Temperature ");
  Serial.print(steinhart);
  Serial.println(" *C");
  delay(1000);
It says it is -273degC and thermister resistance is "inf"
The problem is that the explanations are inadequate.
Old 03-03-13, 09:00 AM   #4
The sketch is not important...
If I understand your post, you are having problems with your sketch. So, it seems that since you are having problems with your sketch, it actually is important... especially if you want someone else to help you. The de-bugger in Arduino is not the best in the world, but it is better than nothing. Sometimes there is an error in some part of the code, and the Arduino de-bugger says it's in another place, so if you do not include your entire sketch, you are wasting everyones time.
It is easiest to see your sketch, if you put it inside CODE tags.
So you would use a square brace "[" and then you would put the letters "CODE" next, and then you would put another square brace "]"... then you put your sketch, your whole sketch next...
...then you would use a square brace "[" and then you would put a slash "/" and then the letters "CODE" next, and then you would put another square brace "]".
It makes your sketch stand out so that it's easier to see what went wrong.
Old 03-03-13, 09:24 AM   #5
The two versions of the code are presented in their entirety above. I thought it was evident enough, perhaps not, so I will try again. I edited it again to show the square brackets. As there is 2 separate codes in the post I said "end post". This is not going in the arduino so i assume it is just for the readers benefit.
The main thing is that there is no plain english glossary that really defines the terms as presented in the debugger. I have my talents but this isn't one of them LOL.
Old 03-03-13, 12:40 PM   #6
i'm no longer a programming expert, but this line looks fishy to me:
it seems you should have something like:
variable = variable + constant
rather than
variable = constant
Old 03-03-13, 01:25 PM   #7
The original sketch looks at the value but does not convert to C nor does it account for the non linearity of the thermister. The Steinhart equation is supposed to do this, to some extent.
Jeff, would you get rid of the steinhart parts? It does need some math to convert.
Old 03-03-13, 05:34 PM   #8
If it were me, I would use what works and build upon it.
Since the original routine reads the thermistor value as it should, I would use it.
It returns the floating point variable READING.
I would take the first code and add a single line that converts the reading to temperature.
Something like this:
float logcubed = log(reading);
logcubed = logcubed * logcubed * logcubed;
float kelvin = 1.0 / (-7.5e-4 + 6.23e-4 * log(reading) - 1.73e-6 * (logcubed));
float celsius = kelvin - 273.15;
the A, B, and C values were stolen from Alan Wendtt from his arduino.cc posting. Your values may or may not vary, IDK.
I learned long ago that the compilers/assemblers/translaters (whatever you call themtoday) tend to work better with these ugly one-line equations without hiccups or weird errors than using many lines to do the same thing.
Once you have the code in that first program spitting out temperatures, use it as a function to do your averaging. As long as you keep the operations separate it will be easy to tell where your program is going wrong.
Old 03-03-13, 06:20 PM   #9
I found an article that is aimed at doing the averaging/smoothing, written in older-school syntax.
Arduino - Smoothing
From this example, it seems to me that you haven't defined your SAMPLES array in the second program correctly. I could be wrong, but constants and variables used to have to be assigned a data type before you could assign them actual values.
If you are looking for a rolling average, a defined array isn't even necessary.
You could simply make a low-pass filter, PID style.
Here's a snip in arduino flavor.
float adcResult = 0;
void setup()
Serial.begin(9600);
void loop()
adcResult = adcResult * 0.95 + analogRead(0) * 0.05;
Serial.println(adcResult);
delay(50);
in this example, alpha is 20, which approximates a 20-point running average.
Old 03-04-13, 04:03 AM   #10
rather than
variable = constant
The line:
Code:
is the same as:
Code:
steinhart = steinhart - 273.15;
so this in itself is not a problem.
As for the
, this means that a variable was not defined inside the function using it (inside main(), for example), nor was it defined globally (before main()). This is an error in C/C++ programming, not Arduino-specific.
If possible please give the full error message, so that we know which variable was not declared, etc.
