Old 08-17-14, 06:04 PM   #221
buffalobillpatrick
A/C I can barely remember my name at 72
I'm gonna be gone for about 12 days. Son is getting married.
This code is not debugged. I think that LCD feedback will help.
Rev06
Code:
void loop()
  readTemps();
  if (SKIP_FLOW_BOOL == false)    readFlows();
  demand = digitalRead(demandPin);
  demand = HIGH;  //debug
  unsigned long current_Time = millis();
  T1 =   current_Time;
  lcd.clear();
  lcd.home (); // go home
  lcd.print(F("curr_Time = "));
  lcd.setCursor(0,1);
  lcd.print(current_Time);
  delay(5000);        //Delay 5 sec
  lcd.clear();
  lcd.print(F("wait_Time = "));
  lcd.setCursor(0,1);
  lcd.print(wait_Time);
  lcd.clear();
  lcd.print(F("wait_Time+2min= "));
  lcd.setCursor(0,1);
  lcd.print((wait_Time + Two_Min));
  if (demand == true)
  lcd.clear();
  lcd.print(F("demand=true"));
  lcd.setCursor(0,1);
  lcd.print(F("WAIT 2 MIN"));
  if ((demand == true)
     && (current_Time >= (wait_Time + Two_Min)))  //Wait 2 min.
  if (runHP == false) hpStart_Time = current_Time;
  lcd.clear();
  lcd.print(F("hpStart_Time = "));
  lcd.setCursor(0,1);
  lcd.print(hpStart_Time);
  runHP = true;
  lcd.clear();
  lcd.print(F("runHP = true"));
  else
  if (runHP == true)
  hpStop_Time = current_Time;
  lcd.clear();
  lcd.print(F("hpStop_Time = "));
  lcd.setCursor(0,1);
  lcd.print(hpStop_Time);
  runHP = false;
  lcd.clear();
  lcd.print(F("runHP = false"));
  //*****HP startup cycle********
  if (runHP == true)
  runInPump = true;
  lcd.clear();
  lcd.print(F("runInPump = true"));
  if ((runHP == true)
     && (current_Time >= (hpStart_Time + Half_Min)))  //Wait 1/2 min comp start
  if (HpLPM > minLPM)  runCompressor = true;
  else runCompressor = true;
  lcd.clear();
  lcd.print(F("runComp = true"));
  if ((runHP == true)
     && (current_Time >= (hpStart_Time + One_Min)))  //Wait 1 min
  runOutPump = true;           //Delay out pump start 60s after starting in pump
  ledState = true;             ///turn on pin 13 led after startup of HP
  lcd.clear();
  lcd.print(F("runOutPump=true"));
  lcd.setCursor(0,1);
  lcd.print(F("ledState=true"));
  //*****HP shutdown cycle********
  if (runHP == false)
  runCompressor = false;
  lcd.clear();
  lcd.print(F("runComp=OFF"));
  if ((runHP == false)
     && (current_Time >= (hpStop_Time + Two_Min)))  //Wait 2 min
  runInPump = false;
  lcd.clear();
  lcd.print(F("runInPump=OFF"));
     && (current_Time >= (hpStop_Time + Five_Min)))  //Wait 5 min
  runOutPump = false;
  lcd.clear();
  lcd.print(F("runOutPump=OFF"));
  wait_Time = current_Time;
  lcd.clear();
  lcd.setCursor(0,1);
  ledState = false;               //turn off pin 13 led after shutdown of HP
  //***Check flow rates above min***
  if (HpLPM < minLPM || HpLPM1 < minLPM)
  if (runHP == true) hpStop_Time = current_Time;
  wait_Time = (current_Time + Ten_Min); //prevent cycle restart for 10m
  runHP = false;
 //***Check evaporator/condensor above/below limits***
 //   not intended for defrost purposes, halts system for 30m
  if (evap_Temp < minEv || cond_Temp > maxCon)
  wait_Time = (current_Time + Thirty_Min); //prevent cycle restart for 30m
  runHP = false;
  digitalWrite(led, ledState);
  digitalWrite(comp, runCompressor);
  digitalWrite(inPump, runInPump);
  digitalWrite(outPump, runOutPump);
  T2 = millis();
  TT = T2 - T1;
  lcd.clear();
  lcd.print(TT);    // 5 sec
  delay(5000);
Old 08-17-14, 06:08 PM   #222
(* delete *)
Old 08-17-14, 06:11 PM   #223
Your name is "BBP"...
Write it down!!
Have a good trip.
-AC (anyway, I think so)
buffalobillpatrick (08-17-14)
Old 08-18-14, 12:09 PM   #224
I rummaged through my Arduino rubble and recovered my LCD display that came with an I2C module.
I soldered on the module and also made the required 4-pin cable.
Then I , hooked up the leads properly and powered up the Uno, verified that power is correctly applied, and that otherwise, nothing else is happening.
So I hunting the web for the next step, and quickly came across THIS page that shows a simple sketch that will locate the address of the I2C.
Code:
//Written by Nick Gammon
 // Date: 20th April 2011
 #include <Wire.h>
 void setup() {
   Serial.begin (115200);
   // Leonardo: wait for serial port to connect
   while (!Serial)
   Serial.println ();
   Serial.println ("I2C scanner. Scanning ...");
   byte count = 0;
   Wire.begin();
   for (byte i = 1; i < 120; i++)
     Wire.beginTransmission (i);
     if (Wire.endTransmission () == 0)
       Serial.print ("Found address: ");
       Serial.print (i, DEC);
       Serial.print (" (0x");
       Serial.print (i, HEX);
       Serial.println (")");
       count++;
       delay (1);  // maybe unneeded?
       } // end of good response
   } // end of for loop
   Serial.println ("Done.");
   Serial.print ("Found ");
   Serial.print (count, DEC);
   Serial.println (" device(s).");
 }  // end of setup
 void loop() {}
I uploaded the sketch to the Uno.
Then I opened the serial window by pressing the "magnifying glass" button, as shown in the image above. Clicking the magnifying glass icon popped open the serial window as shown below.
At first, I was just getting gibberish, but by stepping through all the possible baud rate choices, I finally got the right one (115200 in my case), and was able to clearly read the information I needed to install the I2C LCD assembly.
EDIT: Subsequent examination reminds me that the sketch contained the lines:
void setup() {
...which determined that the baud rate would be 115200.
But all of this begs the question: If I am installing the I2C LCD module, in order to be able to monitor the working of the sketch, why go to the bother and expense of buying and installing the I2C LCD module, when I can simply use the serial window itself to monitor the workings of the sketch??
So for now, that is exactly what I am going to do. All the variants of the LCD display go back into the Arduino parts box...
Name:	Arduino Serial.jpg
ID:	4572   Click image for larger version
Name:	serial window.jpg
ID:	4573   Click image for larger version
Name:	I2C LCD & cable.jpg
ID:	4574   Click image for larger version
Name:	LCD & I2C module.jpg
buffalobillpatrick (08-18-14)
Old 08-18-14, 01:08 PM   #225
buffalobillpatrick
See 1st line of code. your 0x27 goes there.
Serial Monitor window is just fine for debug, but won't be available later when HP Controller is remote from your PC.
& if HP Controller hangs once in a while, when you power it off & connect to a PC then problem might not replicate in reasonable amount of time.
When I use to do Microcode & Power-On Self Test Diagnostic code for a living, I even added a circular Trace Buffer where code continuously traced it's path.
Every functions 1st line of code wrote it's ID into Trace Buffer & any other troublesome area like interrupt handlers.
Great aid for debug & intermittent errors.
And yes, computers, microprocessors, Arduinos, have intermittent errors.
The Following User Says Thank You to buffalobillpatrick For This Useful Post:
AC_Hacker (08-18-14)
Old 08-18-14, 02:01 PM   #226
buffalobillpatrick
I have some questions:
Why delay between In & Out pumps?
Why delay between pumps & compressor?
Why delay on powering down Compressor & pumps?
I think that I understand the need for startup delay. (To avoid Power glitch restarting compressor too soon)
I have no hands on experience on HP
Old 08-18-14, 02:03 PM   #227
(re: post #225)
All very good advice, BBP.
Right now, I'm just trying to verify that I have a sketch, any sketch, that is capable of performing it's very basic functioning.
I have no certainty that we have reached that point right now.
So I am focusing my efforts toward that one goal.
Old 08-18-14, 02:43 PM   #228
I'm not completely certain of Ormston's rationale, but it is required to have a delay between a power lapse and the restarting of the compressor, to protect the compressor against starting when filled with liquid. This is vital.
Then there is the issue that you want to assure that water is flowing before you start the compressor, so that you don't chill the evaporator HX to sub freezing by running the compressor, with no water circulation. This would burst the evaporator HX in an very short time. This is vital. There is a corollary to this which is that you need to make sure that water that has flowed through your evaporator HX is exiting at a temperature that is comfortably above freezing. You need to assure that you have water flowing here to make a measurement of water exiting the evaporator HX. This is vital.
There is an additional issue that it would be preferable, that you have a heated condition in the condenser HX before starting the condenser pump, so you don't pump cold water into the hot water storage tank. This is preferable.
See above. Plus Ormston is going with flow measuring sensors (I don't yet see any other way to do it other than the way he has chosen), so it could take some time to get everything up to speed before measuring.
So that you can squeeze every last BTU out of the HX (the condenser HX) before shutting down the inside loop pump. This delay wouldn't require too much time.
at the same time as the compressor.
I hope Ormston chimes in here, I'd be interested to see what his thinking is regarding the various delays.
Old 08-18-14, 03:13 PM   #229
So that you can squeeze every last BTU out of the condenser HX before shutdown. This delay shouldn't require too much time.
I see no reason why the outside loop pump (evaporator HX circuit) could not be shut down at the same time as the compressor.
Old 08-18-14, 04:13 PM   #230
Ormston
AC/BBP
My thinking behind the delays which may well be flawed.
Startup inlet pump and wait to make sure temp is above minimum including water from far end of ground loop, also make sure flow Meyer is functioning and flow is adequate.
Start compressor.
Output pump delay
From monitoring my ASHP it takes some time from when the compressor starts to when useful heat is available. In my case it takes 5 mins but that is with water flowing through the condenser.
Shutdown
Stop compressor
Delay to stop inlet pump as refrigerant will be passing through expansion device for some time and will continue to remove heat from the evaporator.
Delay to stop outlet pump to extract as much useful heat as possible from condenser as you have already paid for it. This would be better done with in and out temp sensors.
