Old 07-19-21, 11:20 AM   #1
WoodBurner
Default Overcharge Question
If the extra refrigerant just ends up in the receiver, could you make a bigger receiver and have a system that is not sensitive to overcharging?
g
WoodBurner is offline   Reply With Quote
Old 07-20-21, 07:55 PM   #2
MN Renovator
MN Renovator's Avatar
For a vehicle application with a combustion engine, usually the compressor speed isn't controlled by the anything other than whatever the engine speed is and pressure switches turn things on and off instead of everything running at a fixed speed in a critically charged home system. The receiver also allows a bit of long term very slow leakage allowance that generally occurs in a system with a shaft seal. It gives a little bit of leeway for refrigerant quantity, but I think it impacts efficiency if it isn't right where it should be. In either case there will be a point where the system will be overcharged or undercharged, so I'm not really sure if I know how to answer the question you are asking.
Basics about this
https://hvacrschool.com/receiver-basics/
The Following User Says Thank You to MN Renovator For This Useful Post:
WoodBurner (07-20-21)
Old 07-26-21, 09:12 AM   #3
It depends on the system. Lots of ifs and measurements to verify, like in the picture. The main idea is that there's little to no subcooling in the condenser side of the system when a liquid receiver is used. This is a lot more important in an expansion valve metered system than a cap tube system.
WoodBurner (07-31-21)
