Old 06-01-14, 07:16 AM   #11
NeilBlanchard
NeilBlanchard's Avatar
Thanks for the feedback.
Old 06-01-14, 09:02 AM   #12
That Hub seems like a pretty good way to go.
You will have to run cat5 over to your clamp-on amp probe.
It's pretty easy to calibrate an Elite display unit, if you can measure/compare with another device that you trust is reading correctly.
I used my outdoor Nstar meter and later used a clamp-on amp meter.
The Elite LCD display unit has a wide voltage range adjustment, so you can just tweak it up and down and see the wattage display change.
When it matches your standard, it's in cal.. Pretty much..
So, I assume the software App has the same kind of line voltage 'set' parameter.
Or, maybe they have something called a 'Cal' button..
Just got our NStar bill for May!
Old 06-01-14, 08:59 PM   #13
NeilBlanchard
Yes, the charge has gone up quite a bit lately. Last I looked is was 19.2¢/kWh.
