Old 05-26-10, 01:46 PM   #1
Default New Sump pumps save power..
Found these new 1/3 HP pumps that only use about 300 watts..
Basement Watchdog BW1033 - 1/3 HP Submersible Sump Pump
Since I was adding 3 new sump pumps, I looked around for some that
wouldn't be power hogs. I should be able to fire all these up for less than 1kW..
3200 GPH is about 53 gallons a minute. So, no problem keeping up..
The float & control is separate from the pump (for easy replacement)
and has a 10-12 second ON delay after the float drops.
Meaning it's going to get down to the bottom of the barrel..
I've got a little 12VDC to 120VAC inverter that has:
Maximum Continuous Power 400W
Surge Capability( Peak Power) 800W
http://ecorenovator.org/forum/applia....html#post5904
I wonder if it has the guts to start up and run one of these little 1/3HP pumps?
I'm thinking about using the two big LA 12V batteries that I have on my solar chargers..
Humm,
[10w PV]---[Charger]---[12V LA]---[Inverter]---[300w pump]
