Old 07-22-11, 08:48 AM   #41
It shouldn't clog the pump due to the radiators being downstream of the pump, and there will be a filter on the inlet to the pump. I'll have to draw up a diagram soon to show the physical placement of everything. However, I'd imagine just for performance sake it would be a good idea to blast them out with the hose at least. Perhaps even run some vinegar through it?
Old 07-22-11, 08:52 AM   #42
S-F
You Ain't Me
S-F's Avatar
Another thing discovered by water coolers is that vinegar left in the radiator for too long will turn blueish indicating that it's eating the solder. So don't leave it in there for too long. honestly I don't know how one would go about cleaning a radiator out properly.
Old 07-22-11, 09:05 AM   #43
Haha, good to know! Perhaps I'll just flush it out with the hose and be done.
I did take a few minutes to come up with a diagram of what I'm looking at. The radiator is the only part of the system that will be upstairs. The rest of the components will be in the basement.
Old 07-22-11, 09:42 AM   #44
The pump you ordered has a flow of 120GPH, and since you'll have about 2x55+24=134 gallons in the system (2xbarrels+croc, not counting what's in the plumbing and radiator), then you'll pump your whole system throught that rad within 1.5 hours. I wonder how long it'll last, ie how many times it can go through the rad before the water is too warm? Maybe letting it cool off in the basement for the whole night will make up for working it for 4-8h during the day? It'll be interesting to see how it works out.
Old 07-22-11, 10:17 AM   #45
Well, at ~12ft/3m of head, we're looking more at 280LPH/74GPH. So, I should have a bit more capacity and I'm hoping that will help with keeping the drums cool. If I can get the 20F temp drop across the radiator I'm looking at a pretty decent 12,000 BTU/hr for around around 1.75 hrs.
Old 07-22-11, 10:27 AM   #46
Now that I look at the chart, I'm actually not sure what rev my pump is... I just assumed the newer one. I guess if I get the older one I just get a little bonus to the flow rate.
Old 07-25-11, 11:06 AM   #47
I should be getting the pump today. So, I'll be picking up the rest of the components on the way home from work tonight. One part I've had a hard time finding is the check valve to keep the pump primed. I want one with a really low opening threshold. I talked about this project with an engineer here at work and he suggested another solution the the pump priming issue. That is to stick the pump in a PVC pipe that is capped off on one end. Then, put the capped off end of the PVC pipe into the water to get the pump below the water level. Its a very simple solution and is probably cheaper than the check valve considering I have a pipe, so I just need to get a cap. It also doesn't rely on a mechanical device that moves and will eventually fail. The downside is that it will displace some water.
Old 07-27-11, 07:51 AM   #48
Well, work hasn't been progressing on this front very quickly. I did get one of the barrels setup earlier this week. However, lately its been dropping down into the 60s over night and thats plenty to cool the house down to a reasonable level. Still, I have all the bits for the project, I just need to put them together. I also really want to measure things and see what kind of BTUs this simple setup will put out.
Old 07-28-11, 06:57 AM   #49
Today is supposed to be pretty hot and very muggy out, so that gave me the drive to work on this last night. I got quite a bit of the setup in. I have the main tubing run from the radiator down to a single barrel and then back to the sump. The pump dry well is in place. It is 3" PVC with a cap on the end, but it looks like it is leaking. Does anyone have any good ideas on how to seal that up? Silicon? With the dry well leaking I didn't get a chance to prime up the pump and test it out.
I do have pictures, but I didn't have time to get them off the camera. I'll post them up tonight though.
Old 07-28-11, 09:39 AM   #50
How will the radiator be plumbed - cold input at the bottom and warm exit at top?
a/c, air conditioner, diy, geothermal
