04-09-14, 08:20 AM | #1 |
Weanas Plug Power Meter Energy
I found this on amazon today. It appears to be a kill a watt clone. I noticed it is claimed at 3% accurate where as the kill a watt is .2%. However, it is a bit cheaper at $16 (the kill a watt is normally $20). It also has an internal battery, to hold the readings once you unplug it. I tried to find the Weanas website, but there doesn't appear to be one which seems a little fishy. But, they do have quite a few products on amazon.
Weanas(TM) Plug Power Meter Energy
