Old 04-14-16, 08:46 AM   #21
bdgWesternMass
After viewing your link, I am convinced: you have the disease. No doubt about it. I am now thoroughly bewildered. In addition to the genius of Caractacus Potts, you have the work ethic of Willy Wonka as well.
Quotes to support my discovery:
"Caracticus Potts: Mm? Oh. Do you think I'm a lunatic, wasting my time on a lot of silly inventions?
Jemima: But they aren't silly! They're wonderful!
Jeremy: Nobody else can think of them."
"Willy Wonka: [making a mysterious formula] Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple.
Mrs. Teevee: [as Mr. Wonka drinks the formula] That's 105%!
Sam Beauregarde: Any good?
Willy Wonka: [smacks his lips, then speaks in falsetto] Yes."
This is an interesting photo because it happens to be the only piece of polycarbonate I had to cut in the whole curtain wall. I cut it to fit and then I set the table saw to 45 degrees and and cut a chunk but not through the polycarbonate to get a nice fold in the corner.
Seeing the garage project, it is clear now that you cannot use the sand slab for a medium or high temperature heat store, since the space is at least partially finished living space. Doing so would turn that area into a sauna above a certain slab temperature. Unfortunately, that certain temperature is probably below your minimum heating supply water temperature. However, that zone will be particularly easy to heat with low temperature supply water.
I don't plan on changing the temperature I currently operate at.
That is some really nice looking work! Please feel free to write us an encyclopedia about this project.
Incidentally that plywood wall is from our previous apartment that I reused.
I will try to get some current pictures posted soon and more of a narrative.
bdgWesternMass is offline   Reply With Quote
The Following User Says Thank You to bdgWesternMass For This Useful Post:
jeff5may (04-14-16)
