Old 11-02-11, 10:01 PM   #161
Drake
DIY Guy
Wouldn't one want to have greater heat xfer around exterior walls where heat demand is greatest. Not even heat across floor?
Old 11-03-11, 02:16 AM   #162
Ko_deZ
That is why the first place the water flows is along outer walls, you make sure to place it like that. Also you make it double, back and fourth, before looping across the floor.then the warmest water will heat along those walls first, which gives you exactly what you ask for :-)
Ko_deZ is offline   Reply With Quote
Old 11-03-11, 08:25 AM   #163
Drake
DIY Guy
A floor giving off equal heat along whole surface does not match a space that require more heat around exterior walls, less in interior. Hence radiators or heat vents are best placed along exterior walls. I would think a loop design layout that xfers most of heat first along higher heat demand areas would be best design. Decreasing tubing spacing aroung exterior does the same thing if temp is equal thru tubing.
Old 11-03-11, 10:31 AM   #164
Ko_deZ
In order to give any heat at all, the temperature of the water must drop trough the loop, that is the only way to get energy from the heated water. If you place the loop as I said, there will more energy released along the outer wall. Browse back in this thread and see AC_hackers pictures if you need to see it visually. Radiators demand a lot higher water temperature, and you will then need separate circuits. Also, heat pumps are less efficient at higher output temperatures. If your floor heating cannot keep a good temperature along the walls and under windows, you would be beyer off by increasing your insulation, and getting better windows.
Old 11-04-11, 10:51 AM   #165
Default Calculating Pump Size for Hydronic Heating...
Here are a couple of documents that describe how to determine the optimum size pump for hydronic heating:
TD09 - Understanding Pump Curves
TD10 - Selecting Circulators
These are the clearest explanations I have come across. Because these documents address multiple variables, they may need to be read several times, together, to really 'get it'.
The documents apply not only to hydronic heating, but also to GSHP loop fields and the pumping required there. If I had read and thoroughly understood these documents and the principles they explain before I put in my loop field, I would not be digging up part of my loop field right now.
Old 11-17-11, 01:41 AM   #166
pachai
Renovator-in-planning
I have been working on the hydronic floor recently,
and today I tested something.
I may not have learned anything.
I have 600' of radiantec 1/2" O2 barrier stapled
under the floor of a 400 SF area. Below is finished,
will be heated soon.
I tested the pipes under the second floor at 80 PSI air.
I did not schlep the compressor up, I did it with a good bike pump. I had tested it at 30PSI and had seen a
bit of loss every day.
It held an hour at 80 PSI, so I connected it
to the hot water tap, let it run until I saw the pipes
at 125 degrees. (I have a Flir Infrared camera).
I shut the OUT to let pressure build,
then after a bit shut the in.
Using the camera, I did not see any statistically
significant difference in temperature where the
pipes ought to be.
I have seen discussions, I gather
the water has to be moving.
I did see a 25 degree (F) difference between the
first pipe in line and the last pipe before the sink.
The heat must be going somewhere (?!)
(125 degrees in, 99 degrees out)
In the bath, there is a loop in the wall for
a future towel rack. It looked like there might
have been a trace of evidence - a 4" strip
that was 2 degrees higher.
I took pics, but it is hours past my bedtime.
Also, phone USB not working.
pachai is offline   Reply With Quote
Old 11-17-11, 01:55 AM   #167
Did you use aluminum spreader plates? You really should, it's not too late.
Read this.
If you are not circulating the water (with the boiler firing) you only have a small number of BTUs in the water in your 1/2" pipe. when those BTUs migrate out of the water, they will just warm up the immediate surrounding area.
If you are circulating the water through the pipe with the boiler going, it will constantly supply heat to the floor and this constant supply of heat will work its way up through the floor.
You have a big chunk of floor, so you need a big chunk of heat.
Old 11-17-11, 07:32 AM   #168
pachai
Thanks, I DID use plates.
I guess the question is, do I really need
the water *moving* to have it give up its heat?
Or is it that it gave up its heat, and I need to
continuously replenish the heat?
I suppose I can test that - by letting the water out
after 5 minutes and see if it is cold.
(BTW, it takes about 2 minutes for
City water pressure to push through 600'
of 1/2" PEX. I'll measure that better next time.
Also, with a bucket, I can measure how much.)
Thanks
Seth
Old 11-17-11, 07:34 AM   #169
pachai
BTW, at this time, I have no place that I can see
the back of the aluminum plates. Only the pipes going
into the wall and coming back out.
Old 11-17-11, 11:38 AM   #170
Both.
If you just had a circulation pump and your PEX circuit, and the pipe was filled with water heated up to, say 160F, and you ran the pump, you wouldn't see much difference from what you see now. There's just not that much heat in the water in your circuit.
With a staple-up, even with plates, you'll probably need enough heat to continuously supply a feed temperature of at least 155F.
But if you had a boiler continuously supplying heat into the PEX circuit, your house would get warm.
It's not a matter of moving the water, in your case, it's a matter of continuously supplying heat to the moving water.
The boiler is the heat source, and the water is the conveyor of heat. The conveyor has to be moving to bring the new heat in to replace the heat that has is being absorbed by the house, and ultimately leaks out into space.
The water in the pipes doesn't really hold that much heat, but when you continuously inject heat into that water, your floor will become warm.
Is that clearing things up?
Your house is a big heat sink and it need big heat to get warm.
