Old 05-19-13, 08:19 PM   #1
greif
a van down by the river
Default thermostat
Are there any thermostats that are program able just to turn furnace fan on and off? I like to run the fan to circulate the air but running it all the time is probably a waste. There is an add on device to turn fan on off , it's pretty plain only can set to turn on for your desired number of minutes per hour.
ThermGuard
Wondering if there is something better out there
Gary
Gary R
Old 05-21-13, 01:50 PM   #2
I'd imagine any controller for an HRV would be able to do this. Not sure if they make combo heating/cooling/hrv thermostats as I've never had to look for one.
Old 05-21-13, 01:58 PM   #3
Did some quick research. I like LUX... just cause (no real reason). They have one thermostat that does this:
Mechanical Thermostat | Digital Thermostat | Programmable
Introducing the new Lux CAG1500, our fully programmable thermostat that not only gives homeowners the advantage of automatic temperature control, but also has the added benefit of helping to keep a home’s air clean. What makes it all possible is the CAG1500’s innovative Clean Cycle®, a feature that ensures the heating and air conditioning fan runs for a set duration of time each hour to circulate and filter the air in the home. The Clean Cycle® is programmable as well, allowing homeowners to program the fan to run anywhere between 9 and 60 minutes each hour. The CAG1500 also includes a comprehensive graphical filter monitor that indicates when the filter needs cleaning for optimum air quality and system performance.
Old 05-21-13, 04:21 PM   #4
greif
Thanks daox
Gary R
Old 05-22-13, 11:49 AM   #5
Gary,
Get a chepo old Honeywell "round thermostat". The kind with the mercury bulb. Connect the mercury bulb contacts to the wires (two) that turn the furnace fan on.
Cheap, works and I use one in my attic to control the electric exhaust fan up there.
Even better are surplus programmable thermostats where you can program both temperature AND time of day to turn on the attic fan. I use one of those to control a dehumidifier.
Old 06-16-13, 08:51 PM   #6
TackyTeddy
TackyTeddy's Avatar
I know this is not Cheap, but the Nest works for me. Some utilities around the US do offer big rebates for thermostats. Wish are area had them.
http://tackyted.com/storage/solar/NestFanSettings.png
TackyTeddy is offline   Reply With Quote
Old 06-16-13, 09:47 PM   #7
greif
I'm way to cheap for a nest, guess I don't see the need . Haven't gotten around to getting a Lux CAG1500,
Working too much/ too many projects..... that and I forgot
Gary R
Old 06-17-13, 08:44 AM   #8
If/when you do, let us know. I'd be very interested in hearing how it works out.
