#1 |
![]() It would be very useful to collect data from user's experience regarding ASHP performance and Heating Degree Day information, since their applicability is dependent on ambient air temps.
The poll should include:
NOTE: A Heating Degree Data calculator can be FOUND HERE. For the sake of uniformity for comparison, we should go with Fahrenheit with the option to include Celsius in parenthesis. Go for Heating option, use 65F (18C) for base temp, breakdown = average. When the data file is available, the last line will have the yearly HDD average. I'll go first, 1. Sanyo KHS0971 (9,000 BTU) 2. HDD = 4816 (2576) 3. 100% 4. No problems at all, the unit has worked without problem down to 17F This should be very interesting... -AC
#2 |
![]() Shouldn't you also include data on the efficiency/COP depending on HDD? Something like kWh/HDD depending on HDD. I assume that at 17°F your Sanyo consumes more power to do the same amount of work than, say, at 55°F.
Also, wouldn't humidity have an effect on efficiency and/or potential problems? For example operation in around freezing temps will cause icing, etc., as humidity rises.
#3 | |
![]() Quote:
I'm hoping to hear from others about their experiences. -AC
