Old 10-06-13, 04:48 AM   #1
WyrTwister
Default Mini Split Heat Pump Mode
Turned it on a little ago . This is the first time I have used it , as opposed to playing with it .
Seems to give an even heat .
Have the swing louvers pointed almost all the way down . Hopefully , the warm air will mix with the cold / cool air at the floor , before it rises ?
Indoor unit is over the living room exterior door . Having a heat source , at that location , may help with any air leakage / drafts , around the door ?
The internet indicates it is 41 degrees F , outside . Seems to be working OK at that temp ?
When was the last time I mentioned how quiet it is ?
God bless
Wyr
Old 10-06-13, 10:54 AM   #2
Originally Posted by WyrTwister View Post
...God bless...
I'm a little new to this field...
Are the blessings cumulative (do they continue to add up), or does each blessing supersede the previous blessing?
Old 10-06-13, 12:05 PM   #3
WyrTwister
Yes .
God bless
Wyr
