Old 10-12-13, 05:40 AM   #1
ferox
Thumbs up plastic hot water tank with heat pump backup
Hi to all
My solar hot warer tank is maded from a 1000L PP plastic tank used for chemichal produts, inside I have 4 pieces of beer keg 50L each, 10cm insulation, the top of the tank is used for storing.
The heat pump is a 24000btu R22 external unit with a direct heat in the tank with a copper coil 40m long, diam. 9.52mm.
I made a test to heat the tank to 60 deg Celsius and it works fine, I must test this at low temperatures 0 deg C. From 40C to 46 in 1h
I will made the controller for the heat pump with arduino, the solar controller is maded with arduino with data loged on xively
I will put picture and links later, I'm to new hear.
ferox is offline   Reply With Quote
Old 10-12-13, 06:34 AM   #2
ferox
The heat pump is modified a litle, I made to run in the summer whet the oustide temperature is more then 5 C and with water in the winter when is 5 C bellow (the winter side is not ready yet).
I do not know if it was worth it, but it was the simpliest way to start fror somewere, without masive change for pipings.
If you have some tips for this setup please leave a comment.
Old 10-12-13, 06:35 AM   #3
ferox
I made a litle schetch to understand beter what I thought.
Old 10-12-13, 06:54 AM   #4
ferox
The schetch
Name:	schema pompa de caldura3.JPG
Outside unit panasonic R22 24000 btu
tank
ID:	3482 Click image for larger version
ID:	3483 Click image for larger version
ID:	3485 Click image for larger version
Inside and outside the tank
ID:	3486 Click image for larger version
Solar and heat pump heat exchanger
ID:	3489 Click image for larger version
Old 10-12-13, 08:19 AM   #5
Why is there a reversing valve? Ground source doesn't need to defrost.
Old 10-12-13, 09:03 AM   #6
ferox
I got the air conditioner with this valve and made minimal change posible.
The ground surce part is not done yet and maybe I'll use in this winter.
I invest just in the coper coil, external unit I received for free from a friend.
Old 10-12-13, 09:22 AM   #7
Scifficus
DIY addicted!
How thick is the insulation?
Scifficus is offline   Reply With Quote
Old 10-12-13, 09:32 AM   #8
ferox
insulated with extruded polistyren in most of the parts, 10cm.
temperature loss is ~2 Celsius in 6 hours.
logged data from xivley for beter improving https://xively.com/feeds/541753585
the pump and the heatpump is not logged, rapid heating of the tank is with heat pump turned on.
Old 02-09-17, 09:08 AM   #9
Ron342
Default link?
May want to check your link, shows up bad for me?
Old 02-09-17, 10:20 AM   #10
Fordguy64
This thread is almost 4 years old.. Links are probably bad.
