Go Back   EcoRenovator > Improvements > EcoRenovator Blog Discussion
Old 09-29-11, 07:16 AM   #1
ER Blogger
Default EcoRenovator 2011 Fall Giveaway Donators – LUX
LUX is a maker of a few different products. They make mechanical, digital and programmable thermostats. They also have a line of timers, grab bars for showers, and range (cook top) parts. It may seem like an odd assortment of products, but they are probably most widely known for their line of [...]Post from: EcoRenovator.org
More...
ER Blogger is offline   Reply With Quote
Old 09-29-11, 09:27 AM   #2
While writing this article I found out about the 'swing' setting on the LUX thermostats. I happen to have an older LUX thermostat in my house and found that I have the same swing setting. Its not an obvious command and you have to look it up in the manual on how to do it, but I think I should see some savings from increasing my swing setting. It was at 1 degree F (which means +/- 1F) and now its set to 1.5F. This translates to longer furnace on times, and reduced cycling which used to be an issue for me before I did a few other things. It'll be interesting to see if increasing the swing will help even more.
