Old 05-26-13, 07:17 PM   #1
fabieville
Default LM723 60 amp voltage regulator
I'm trying to design a 60 amp voltage regulator using LM723. I'm going to use the circuit below that is rated for 10amps but I am going to modify it so that it can handle 60amp. Apart from adding more 2n3055 transistors what else do i need to add or change so that it can handle 60amp? Or can i just add the external transistors along with the heat resistors and that's it?
See the attached thumbnail for the circuit diagram.
Name:	10amp regulator.gif
fabieville is offline   Reply With Quote
