#1 |
![]() I was reading on an i-miev (Mitsubishi electric car) forum about these devices. While not cheap compared to the kill a watt, they at least are an option.
EKM - Electric Meters (KWh Meters)
#2 |
![]() I just picked up the Efergy Elite kw meter for a song. It uses clamps over your service wires inside your breaker panel. It gives a nice real time reading. It immediately drove me nuts to see the power im consuming at idle! And od course even worse when the appliances are running.
#3 |
Steve Hull
![]() Where did you get it (Efergy Elite Meter) and how much?
Steve
#4 |
![]() They're out there on Amazon $113 and ebay for less. Mine was an open box special for $35. They come standard with only one sensor, which works for folks with balanced 220v. The sensor for my other leg was $20 more. The same unit has inputs for up to 3 sensors and 3 phase power.
The Following User Says Thank You to gtojohn For This Useful Post: | Daox ![]() |
