Old 08-09-14, 04:02 PM   #1
buffalobillpatrick
Default Solar Differential Controller Arduino Code
Code:
 * ARDUINO SOLAR Differential Controller.
 * In Setup: Read & Display the 2x Control Pots:
 * ON_DELTA & OFF_DELTA
 * In Forever Loop: Read & display 2x 10K NTC Sensors:
 * PANEL_TEMP & TANK_TEMP
 * If Pump is ON:
 * If (PANEL_TEMP - OFF_DELTA) is less than or = TANK_TEMP
 * or TANK_TEMP is greater than or = TANK_MAX_TEMP
 * Then Turn Pump & LED OFF and set PUMP_BOOL to false
 * Else Pump is OFF:
 * If (PANEL_TEMP - ON_DELTA) is greater than or = TANK_TEMP
 * AND TANK_TEMP is Less than or = TANK_MAX_TEMP
 * Then Turn Pump & LED ON and set PUMP_BOOL to true
 * Next display PUMP_BOOL status: 0 = OFF, 1 = ON
 * INPUTS:
 * Reset switch            //Reset pin switched to Gnd & released
 * ON_DELTA_POT            //control pots
 * OFF_DELTA_POT
 * PANEL_sensor            //2X 10K NTC Thermisters
 * TANK_sensor
 * OUTPUTS:
 * LCD Display: Status & Progression through code
 * PUMP_RLY
 * PUMP_LED  //LED Pin 13 on Arduino board
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h>
#define I2C_ADDR    0x3F // <<----- Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN     3  //define LCD digital pins
#define En_pin  2
#define Rw_pin  1             //can't use D0 & D1 Tx Rx
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5              //can use 2 -> 12 below in code
#define D6_pin  6
#define D7_pin  7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
#define SDA                   A4  //RESERVE I2C for LCD
#define SCL                   A5
#define ON_DELTA_POT          A0
#define OFF_DELTA_POT         A1
#define PANEL_sensor          A2
#define TANK_sensor           A3
                // D0 = RX, D1 = TX, reserved
                                     // digital output pin relay control
#define  PUMP_RLY             2
#define  PUMP_LED            13
#define  TANK_MAX_TEMP      160
int PANEL_TEMP;
int TANK_TEMP;
//int I;
int ON_DELTA;
int OFF_DELTA;
static bool PUMP_BOOL = false;
void setup(void)
  pinMode (PUMP_RLY,             OUTPUT);
  pinMode (PUMP_LED,             OUTPUT);
  digitalWrite (PUMP_RLY,        LOW); //OFF
  digitalWrite (PUMP_LED,        LOW); //OFF
  pinMode (TANK_sensor,          INPUT);
  pinMode (PANEL_sensor,         INPUT);
  lcd.begin (16,2); //  <<----- My LCD is 16x2
  lcd.clear();
  //Switch on the backlight
  lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.clear();
  lcd.home (); // go home
  lcd.print(F("DIFFER-DUINO"));
  lcd.setCursor(0,1);
  lcd.print(F("1_0"));
  delay(5000);
  ON_DELTA        =    ((Read_10K_NTC (ON_DELTA_POT)  / 10));  // 15
  OFF_DELTA       =    ((Read_10K_NTC (OFF_DELTA_POT) / 50));  //  2
  lcd.clear();
  lcd.print(F("ON DELTA = "));
  lcd.print(ON_DELTA);
  lcd.setCursor(0,1);
  lcd.print(F("OFF DELTA = "));
  lcd.print(OFF_DELTA);
  delay(5000);
  }    //end setup
void loop ()
                    //read & display the 2 10K NTC Sensors
  PANEL_TEMP  =  (Read_10K_NTC (PANEL_sensor));
  TANK_TEMP   =  (Read_10K_NTC (TANK_sensor));
  lcd.clear();
  lcd.print(F("PANEL TEMP="));
  lcd.print(PANEL_TEMP);
  lcd.setCursor(0,1);
  lcd.print(F("TANK TEMP="));
  lcd.print(TANK_TEMP);
  delay(5000);
  // If Pump is ON:
  // If (PANEL_TEMP - OFF_DELTA) is less than or = TANK_TEMP
  // or TANK_TEMP is greater than or = TANK_MAX_TEMP
  // Then Turn Pump & LED OFF and set PUMP_BOOL to false
  if ( PUMP_BOOL)
  if ((( PANEL_TEMP - OFF_DELTA ) <= TANK_TEMP )
       || ( TANK_TEMP >= TANK_MAX_TEMP ))
  PUMP_BOOL =false;
  // Else Pump is OFF:
  // If (PANEL_TEMP - ON_DELTA) is greater than or = TANK_TEMP
  // AND TANK_TEMP is Less Than or = TANK_MAX_TEMP
  // Then Turn Pump & LED ON and set PUMP_BOOL to true
  else if ((( PANEL_TEMP - ON_DELTA ) >= TANK_TEMP )
      && ( TANK_TEMP <= TANK_MAX_TEMP ) )
  digitalWrite (PUMP_RLY,       HIGH); //ON
  digitalWrite (PUMP_LED,       HIGH); //ON
  PUMP_BOOL = true;
  lcd.clear();
  lcd.print(F("PUMP = "));
  lcd.print(PUMP_BOOL);
  delay(5000);
} //end forever loop
int Read_10K_NTC (int which_sensor)
  #define sample_cnt 30
  float alpha =   0.9;     // factor to tune
  float average = 0.0;
  float steinhart;
  int I;
// resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// TEMP. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// The beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3892
// the value of the series resistor
#define SERIESRESISTOR 10000
  for (I=0; I< sample_cnt; I++)
  average =  alpha * analogRead(which_sensor) + (1-alpha) * average;
  delay(10);
  // convert the value to resistance
  average = 1023 / average - 1;
  average = SERIESRESISTOR / average;
  steinhart = average / THERMISTORNOMINAL;     // (R/Ro)
  steinhart = log(steinhart);                  // ln(R/Ro)
  steinhart /= BCOEFFICIENT;                   // 1/B * ln(R/Ro)
  steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
  steinhart = 1.0 / steinhart;                 // Invert
  steinhart -= 273.15;                         // convert to C
  return (round(steinhart * 1.8) + 32);       // round to whole number
                                              // & convert to F
}  // end of Read_10K_NTC
The Following User Says Thank You to buffalobillpatrick For This Useful Post:
where2 (08-09-14)
Old 08-09-14, 07:56 PM   #2
where2
DIY Geek
Do you have this running, and if so what shield(s) are you using to acquire the temperature data?
Old 08-09-14, 10:38 PM   #3
buffalobillpatrick
Yes it's running. No shield is needed.
10K NTC sensors connect at
see: https://learn.adafruit.com/thermistor?view=all
A voltage divider circuit is built. A 10K 1% resistor is soldered in series with 10K NTC thermistor & wired across +5 & Gnd.
The sensor wire to A2 or A3 wire is soldered to the middle of voltage divider.
Every brand of 10K NTC Thermistor possibly has a different Beta which "YOU" would specify in the Read_10K_NTC function.
The ones I'm using are:
You could also:
#define ON_DELTA 16 or 20
#define OFF_DELTA 2 or 3
instead of 5K pots, but I like pots instead of re-compiling 5 years from now.
Old 08-11-14, 07:58 PM   #4
buffalobillpatrick
Arduino Uno & Crydom D1202 SSR Relay are in the white box.
(This relay is rated at 2.5A 120vac so a much larger pump could be used)
When Panel sensor is 20*F or more hotter than Tank sensor,
the Arduino energizes Relay.
The Relay powers the 30VDC 1A Power Supply,
which powers the 24-30VDC El-Sid 10W pump.
When Tank sensor rises to within 2*F of the Panel sensor,
the Arduino de-energizes the Relay.
This setup is for a small system in my 8'x16' trailer.
1 3'x8' panel & 40 gallon tank, heats radiant floor.
A cheap mercury thermostat controls a seperate 12VDC El_Sid pump for floor loop.
ID:	4546   Click image for larger version
ID:	4547   Click image for larger version
