09-11-11, 06:44 PM | #1 |
Solar Powered Food Dryer
DIRECTIONS:
NOTE: Also works for fruit. -AC_Hacker
09-12-11, 12:26 PM | #2 |
Does your high-tech solar food dryer system work with a non-hybrid hatchback?
Thanks, Tim
- DIY Adventures in Applied Sustainability - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
09-12-11, 02:01 PM | #3 |
Now that's Japanese technology at its best - solar hybrid
09-13-11, 11:45 AM | #4 | |
Our research department has not at this time verified that a non-hybrid hatchback food dryer will work as described. Theoretically, it should work... and the possibility exists that it could work almost as well as the hybrid hatchback food dryer. I encourage you to try it on your own, but with the warning that if you are not pleased with the results, DO NOT RETURN YOUR NON-HYBRID HATCHBACK TO US as we are understaffed and can not handle the inventory at this time. Best of luck, and may your food be as dry as your wit, -AC_Hacker (Director R&D) International Hybrid Hatchback Food Dryers, LLC
I'm not an HVAC technician. In fact, I'm barely even a hacker... Last edited by AC_Hacker; 09-13-11 at 11:52 AM.. |
