Old 08-28-15, 07:55 AM   #11
mechanic
You must have fairly mild winters there if you can still ride... How deep are your loops? My loops are all buried between 8 and 9 feet, our frost line usually gets down about 6 ft.
mechanic is offline   Reply With Quote
Old 08-28-15, 09:12 AM   #12
Originally Posted by TechShop View Post
...Here are some photos of the shop, I'll start detail the GSHP hydronic conversion in a following post to this thread...
I can't see any of the photos that you have posted.
I have even gone into the "HTML" code and tried to copy and paste your photobucket image address (AKA: "URL") in my browser, to view the indicated image, and there's nothing there...
What's going on??
Old 08-28-15, 10:56 AM   #13
What's going on??
You are not alone, man. Something is awry with the internet of late. Post a comment in the thread about posting pictures. A few of my friends/relatives have been having the same issues. Works for me on their WiFi on my phone, not in their equipment. Don't know why.
Old 08-28-15, 02:40 PM   #14
Humm, I see all the pictures . . . .
Old 08-28-15, 03:38 PM   #15
mechanic
I see them as well
Old 08-28-15, 03:54 PM   #16
TechShop
FNG
Yeah, it's super mild. I'm in Western Washington, we rarely see anything less than 27 or 28 degrees, but that's short lived. I think our annual average temps are in the mid 40's. We get a consistent warm air current from the Pacific Ocean. I went about 6' to 8' on these test loops. We don't get frost below a foot here and actually, even 6" of frost is rare.
Most of my soil is mostly sand with a small bit of clay. It soaks up the rain and drains very well. Great for a winter MX practice track.
Old 08-28-15, 03:58 PM   #17
TechShop
FNG
What's going on??
That's strange. Perhaps photobucket doesn't support other platforms very well? I'm using Windows 8.1 with the IE browser version 11.
Here's a URL directly to my recent uploads there...
C W's Recent Uploads | Photobucket
Old 09-03-15, 01:15 PM   #18
TechShop
FNG
Made a little more progress on the conversion project this week.
I finished up all the brazing and did a pressure test with nitrogen at 300 PSI on the refrigerant circuit. The water side (including the pump) was previously tested with compressed air at 50 PSI.
I also constructed a steel upper frame around the components I've added to the heat pump. The structure allows me to use all of the original sheet metal. I just have to come up with a 12" tall panel for each of the four sides.
I have purged with nitrogen a few times and the system sitting under vacuum, but I need to come up with a micron vacuum gauge before I release the refrigerant into the upper section. In the next few weeks I will be making all of the liquid and electrical connections. Hopefully I'll start heating up this concrete slab around the end of the month.
Old 09-03-15, 01:17 PM   #19
TechShop
FNG
*edit: removed links and uploaded images*
ID:	5833   Click image for larger version
ID:	5834   Click image for larger version
Old 09-04-15, 08:04 PM   #20
Yeah, I can definitely see every thing there. Everything there is wrapped in a photobuchet URL, so there's a lot of chance that permissions may not be conveyed properly.
I upload my pix to EcoRenovator, so the chain of addresses to the photo is very short.
