Old 06-16-15, 05:48 PM   #241
It is a very hot 95F here. My house is set @78F and the whole house is only using 2KW
power right now. That is for everything running. Pool pump, aquaponics pump, TV ...
We are running all four mini splits. That is one reason why I like the Mini splits.
We are making 7.5KW in solar power right now.
Sounds like a Solar Moment.
How does your energy balance look over the span of a month?
Old 06-16-15, 06:01 PM   #242
We get zeroed out March 1. So from March 1 2015 until today we have banked 1,667KWh.
Last year Sept we carried forward 3,652 kwh (banked)
Last winter we used 2,862 kwh extra to heat with. So we made all our power for the year.
We did not use any natural gas to heat with all last winter just mini splits.
We have to make extra power in the summer to cover our winter mini splits heating and we drive our Chevy Volt more in the winter. We charge it twice a day in the winter.
Flynns Arcade 12.560kW
Old 06-16-15, 06:57 PM   #243
That's amazing PV power!
When it was 85F here last week, we had both Sanyos running in the
dehumidifier mode at 75F. Each unit was using about 350 watts.
We even left them on at night when it dropped to under 65 outdoors.
They use hardly any power, but kick-in when the sun comes back up.
May as well not turn them off on cool nights, since the crankcase heaters
will suck down 40w each all night long..
When they are On, but with no motors running, they only use about 10w..
Old 02-05-16, 11:25 AM   #244
I just wanted to update this post. We have been running the Mini splits just over two 1/2 years now. This is the second year where we have not turned on our natural gas heat or our 4 ton out door AC unit. Not even once.
We have not missed them at all. We now stay warmer in the winter and cooler in the summer than before.
I would like to say we conserve power but we don’t the living room is set 75-76 F I use to turn it down at night but I don’t anymore. My office 73 F kid’s rooms in the day time 70F.
We should still net zero this year. It is not unusual to to have all the rooms a few degrees different we all like to be a different temps. This works well with mini splits.
We are still very happy with the Gree units LG units are doing well but we like the GREE units better.
Gree has a unit that is one step up from the ones I installed. It is 30.5 SEER!
It can put out full heat at -20 F and it talks Wi-Fi to your phone to control the unit.
Two very nice features. It has a Variable Speed 2-Stage Compressor.
GREE Crown Series 9,000 BTU Single-Zone Ductless Split
http://www.greecomfort.com/our-products/crown/
Xringer (02-05-16)
Old 02-05-16, 12:39 PM   #245
WyrTwister
Glad you are enjoying your MS's . :-)
The new unit you described sounds pricey ?
God bless
Wyr
Old 02-05-16, 12:49 PM   #246
God bless
Wyr
It is listed at 1,211.99 take 5% off that for the sale and add a line set. The Mitsubishi with about the same specs is but no Wi-Fi 1,669.99 plus add a line set. Both have free shipping.
I paid about 1K with a line set include so it is more money.
Old 02-05-16, 03:50 PM   #247
Wow.. That spec sheet says -22 def F!!
Now that sounds like the MS for me!!
Just need four or five of them to replace both the old Sanyo 24,000 BTU units..
Old 02-05-16, 04:13 PM   #248
They make a 9,000, 12,000 and a 18,000 BTU that all go to a -20 F and if you look at their capacity range they are under rated.
18K Capacity Range 4,436 -21,496 BTU/H
Old 02-05-16, 10:52 PM   #249
ctgottapee
You still want the Fujitsu H line or the add on pan defroster for the Mits of similar specs
Those are impressive specs for that price, matching the 2nd to last gen of each of the major makers at nearly a $500 discount.
The recent gen of each model has pushed the heat performance for how we would use it.
One thing I saw on an energy forum to look at is the range/curve in which the models run. It noted the Mits had much larger range, ie could operate at lower output.
On the third winter of heat pump only and this winter has been much more hospitable to it's limits.
They still struggle during long cold snaps with constant defrost and lower spec output, and the energy savings drop far below the cheap natural gas.
Old 02-06-16, 05:45 AM   #250
Any air source unit that has a cop of 3 at 17 degrees is good enough for me. I can burn wood if it gets below zero!
